This Ezra saber is giving me fits today, haha. So, I got this Ezra lightsaber with a blaster function. it has a little switch that you can slide to go into blaster mode and then back to saber. anyways, I tried to set it up the way I like with fett’s controls and edit mode and everything, and it crashed halfway through. so, I decided to just put it back to original settings with the config the seller gave me. Unfortunately, now that doesn’t work either, of course. the button no longer functions at all unless it is in blaster mode. the fact that it works in blaster mode leads me to believe it’s a config issue, though. I feel like the main button isn’t indicated properly. any thoughts on what could be causing the issue? here is the config and a pic of the board:
Well, The SaberBlasterProp is an enigma to me, so I don’t know what a correct configuration looks like for it, but I can’t help but notice you have a button object configured for BUTTON_FIRE using the main button, but the BUTTON_POWER object is commented out… Are both perhaps meant to be there?
I’m not sure if both buttons (even though they’re physically the same) need to be configured or if there is a way to configure it otherwise, but I’d imagine that’s the issue based on what you describe.
thanks for taking a look. I thought the same. I tried a couple combinations of adding those two extra lines without any luck.
When using Dual Prop, you leave the pow and aux buttons defined as they are for a saber. The code handles transing them to blaster buttons.
Now you only have one button, so the mode select or reload is not going to work for you with things as-is. That means you probably want to unlimit your shots since you can’t reload without a power cycle, so remove
#define BLASTER_SHOTS_UNTIL_EMPTY 1000 // (whatever number)
But it will pew-pew.
so, do I need to change this part?:
//Button PowerButton(BUTTON_POWER, powerButtonPin, "pow");
// Button ModeButton(BUTTON_MODE_SELECT, auxPin, "modeselect");
I tried taking out the // on the other two, but that didn’t help.
I also omitted the blaster shots til empty part, but that didn’t seem to make a difference.
Yes, I just posted what it should be.
Because that’s not the right way to do it when you are using Dual Prop.
That’s going to prevent Empty, which is good, since you don’t have a way to reload without some code modification or adding another button.
weird. I don’t know what’s going wrong. I tried the way you had it posted, and it didn’t work. the main button stopped working for blaster as well and still didn’t work for the blade activation. the switch to flip them back and forth still worked, but I couldn’t get it to fire in blaster mode or ignite the blade in blade mode. I thought maybe it was just the button malfunctioning, but it works for the blaster mode if I have Button FireButton(BUTTON_FIRE, powerButtonPin, "fire"); enabled. any other ideas?
Side note, aren’t your blaster and saber presets reversed?
Is the pastebin in the first post the original config file that came with the saber?
You should have a backup version, unedted, saved somewhere safe that you can always go back to.
You should compare the differences to a version that you changed something, see what’s different. That’s the part that broke it.
You can always just load up the original version (that worked, right?) and then try editing again on a new copy.
I don’t know about the blaster and saber presets being reversed. I thought it looked that way, too, so I changed the top part to blaster and the bottom part to blade, but that just put the blade sound in blaster mode.
this is the config file that they sent me. unfortunately, this is supposed to be the original. I don’t have any backup to compare it to. I don’t know how to have a backup version without the correct original config, I guess. I really really wish I could just load up the original version that worked. I just wanted to add a few blade styles and edit mode and such. didn’t know this was going to happen.
it’s not a lost cause y any means, just something silly. you can always reupload a working config and ot’ll be fine. we just need to figure out what’s wrong. Let me actually copy the config and test some things. Hang on.
you’re awesome. thanks a ton.
it’s really bizarre. the only thing that appears to be a problem is the main button for blade mode. the blaster works, and with a blade inserted, I can ignite the first preset with gestures. but I can’t do anything that requires the button while in blade mode. that has to be something with the config, right? I initially tried to change it to Fett controls like you mentioned earlier, but the saber did nothing after uploading. here was my config for that:
I also saw that the config indicates 3 blades. is that one for the blaster, one for the blade, and one for the crystal?
I really don’t care about any of the presets or fonts on the config. I can add all those on my own. I just want a functioning config. it worked really well aside from the settings. super bummed.
Correct.
minor issue: Your last saber preset “Fire” has an overloaded Red value (that’s giving you a bunch of Rgb warnings in Arduino I bet.)
Fix the Rgb<280,0,0> to be Rgb<255,0,0> -
Swap the preset array names to be saber and blaster appropriately. Put NO_BLADE array first in the BladeConfig.
When NO_BLADE is active, that means it’s blaster time, use the blaster presets, so I don’t know why that was reversed. -
Tested on a saber, and the answer is…
You have the saber and blaster classes reversed in the prop file inclusion section.
#define PROP_TYPE SaberBlasterProp<Blaster,SaberSA22CButtons>
should be
#define PROP_TYPE SaberBlasterProp<SaberSA22CButtons, Blaster>
Works fine after that ![]()
okay, I changed the prop type but didn’t get any change. I didn’t swap the presets yet, though, so, do you mean just cut all the blade types under preset blaster [] and swap them with the presets that are under preset saber []?
thanks again for taking the time to help out with this. I really do appreciate it.
Not quite. I meant swap the
Preset blaster[] = {
and
Preset saber[] = {
here.
#define NUM_BLADES 3
#define NUM_BUTTONS 1
#define VOLUME 1500
#define CLASH_THRESHOLD_G 3.0
#define BLADE_DETECT_PIN blade4Pin
#define SAVE_STATE
#define SA22C_SWING_ON
#define SA22C_TWIST_OFF
#define SA22C_THRUST_ON
// --------- blaster --------------
// #define ENABLE_BLASTER_AUTO
// #define BLASTER_SHOTS_UNTIL_EMPTY 1000 // (whatever number)
#define BLASTER_JAM_PERCENTAGE 0 // if not defined, random.
#include "../props/dual_prop.h"
#include "../props/saber_sa22C_buttons.h"
#undef PROP_TYPE
#include "../props/blaster.h"
#undef PROP_TYPE
Preset saber[] = {
{ "Blue", "tracks/bgm1.wav",
StylePtr<Layers<AudioFlicker<Blue,Blue>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<200>>,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveDragL<BrownNoiseFlickerL<White,Int<300>>,TrWipeIn<400>,TrFade<400>>,ResponsiveMeltL<Mix<TwistAngle<>,Red,Orange>,TrWipeIn<600>,TrSmoothFade<600>>,InOutTrL<TrWipe<300>,TrWipeIn<800>,Black>>>(),
StylePtr<Layers<
AudioFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,128>>>,
ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,
ResponsiveStabL<Red>,
ResponsiveClashL<White,TrInstant,TrFade<400>>,
InOutTrL<TrWipe<300>,TrWipeIn<500>,Pulsing<Blue,Black,5000>>>>(),
StylePtr<Black>(), "0"},
{ "Red", "tracks/bgm1.wav",
StylePtr<Layers<AudioFlicker<Red,Red>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Blue,300>,50,1>,TrConcat<TrInstant,White,TrFade<200>>,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveDragL<BrownNoiseFlickerL<White,Int<300>>,TrWipeIn<400>,TrFade<400>>,ResponsiveMeltL<Mix<TwistAngle<>,OrangeRed,Orange>,TrWipeIn<600>,TrSmoothFade<600>>,InOutTrL<TrWipe<300>,TrWipeIn<800>,Black>>>(),
StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Red,White>,AudioFlicker<Red,White>>,White>, 300, 800,Pulsing<Red, Black, 5000>>>(),
StylePtr<Black>(), "Red"},
{ "Cyan", "tracks/bgm6.wav",
StylePtr<Layers<AudioFlicker<DeepSkyBlue,DeepSkyBlue>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<200>>,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveDragL<BrownNoiseFlickerL<White,Int<300>>,TrWipeIn<400>,TrFade<400>>,ResponsiveMeltL<Mix<TwistAngle<>,Red,Orange>,TrWipeIn<600>,TrSmoothFade<600>>,InOutTrL<TrWipe<300>,TrWipeIn<800>,Black>>>(),
StylePtr<InOutHelper<SimpleClash<Lockup<Blast<DeepSkyBlue,White>,AudioFlicker<DeepSkyBlue,White>>,White>, 300, 800,Pulsing<DeepSkyBlue, Black, 5000>>>(),
StylePtr<Black>(), "Cyan"},
{ "Cyan2", "tracks/bgm6.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,0,128>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>(),
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,0,128>>> ,InOutTrL<TrInstant,TrFade<300>,Pulsing<RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,4,10>>,3000>>>>(),
{ "Red2", "tracks/bgm1.wav",
StylePtr<Layers<Stripes<10000,-1700,RotateColorsX<Variation,Rgb<80,0,0>>,RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>,RotateColorsX<Variation,Rgb<50,0,0>>,RotateColorsX<Variation,Red>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>(),
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>> ,InOutTrL<TrInstant,TrFade<300>,Pulsing<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<10,0,0>>,3000>>>>(),
StylePtr<Black>(),"Red"},
{ "Red3", "tracks/bgm1.wav",
{ "Purple", "tracks/bgm4.wav",
StylePtr<Layers<AudioFlicker<Magenta,Magenta>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<200>>,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveDragL<BrownNoiseFlickerL<White,Int<300>>,TrWipeIn<400>,TrFade<400>>,ResponsiveMeltL<Mix<TwistAngle<>,Red,Orange>,TrWipeIn<600>,TrSmoothFade<600>>,InOutTrL<TrWipe<300>,TrWipeIn<800>,Black>>>(),
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,RotateColorsX<Variation,Rgb<48,0,105>>>,InOutTrL<TrInstant,TrFade<300>,Pulsing<RotateColorsX<Variation,Rgb<95,0,210>>,RotateColorsX<Variation,Rgb<4,0,9>>,3000>>>>(),
StylePtr<Black>(),"Purple"},
{ "Green", "tracks/bgm4.wav",
StylePtr<Layers<AudioFlicker<Green,Green>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<200>>,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveDragL<BrownNoiseFlickerL<White,Int<300>>,TrWipeIn<400>,TrFade<400>>,ResponsiveMeltL<Mix<TwistAngle<>,Red,Orange>,TrWipeIn<600>,TrSmoothFade<600>>,InOutTrL<TrWipe<300>,TrWipeIn<800>,Black>>>(),
StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Green,White>,AudioFlicker<Green,White>>,White>, 300, 800,Pulsing<Green, Black, 5000>>>(),
StylePtr<Black>(),"Green"},
{ "Green2", "tracks/bgm4.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,128,0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>(),
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,128,0>>> ,InOutTrL<TrInstant,TrFade<300>,Pulsing<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,10,0>>,3000>>>>(),
StylePtr<Black>(), "Green"},
{ "Blue2", "tracks/bgm5.wav",
StylePtr<Layers<HumpFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,128>>,50>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>(),
StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Blue,White>,AudioFlicker<Blue,White>>,White>, 300, 800,Pulsing<Blue, Black, 1500>>>(),
StylePtr<Black>(), "Blue"},
{ "Yellow", "tracks/bgm7.wav",
StylePtr<Layers<AudioFlicker<Yellow,Yellow>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<200>>,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveDragL<BrownNoiseFlickerL<White,Int<300>>,TrWipeIn<400>,TrFade<400>>,ResponsiveMeltL<Mix<TwistAngle<>,Red,Orange>,TrWipeIn<600>,TrSmoothFade<600>>,InOutTrL<TrWipe<300>,TrWipeIn<800>,Black>>>(),
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Rgb<180,130,0>>,RotateColorsX<Variation,Rgb<90,65,0>>> ,InOutTrL<TrInstant,TrFade<300>,Pulsing<RotateColorsX<Variation,Rgb<180,130,0>>,RotateColorsX<Variation,Rgb<7,5,0>>,3000>>>>(),
StylePtr<Black>(), "Yellow"},
{ "Yellow2", "tracks/bgm7.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Rgb<180,130,0>>,RotateColorsX<Variation,Rgb<90,65,0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>(),
StylePtr<InOutHelper<SimpleClash<Lockup<Blast<Yellow,White>,AudioFlicker<Yellow,White>>,White>, 300, 800,Pulsing<Yellow, Black, 5000>>>(),
{ "Silver", "tracks/bgm7.wav",
StylePtr<Layers<AudioFlicker<Rgb<100,100,150>,Rgb<100,100,150>>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<200>>,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveDragL<BrownNoiseFlickerL<White,Int<300>>,TrWipeIn<400>,TrFade<400>>,ResponsiveMeltL<Mix<TwistAngle<>,Red,Orange>,TrWipeIn<600>,TrSmoothFade<600>>,InOutTrL<TrWipe<300>,TrWipeIn<800>,Black>>>(),
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Rgb<100,100,150>>,RotateColorsX<Variation,Rgb<50,50,75>>> ,InOutTrL<TrInstant,TrFade<300>,Pulsing<RotateColorsX<Variation,Rgb<100,100,150>>,RotateColorsX<Variation,Rgb<4,4,6>>,3000>>>>(),
StylePtr<Black>(), "Silver"},
{ "Rainbow", "tracks/bgm7.wav",
StylePtr<Layers<AudioFlicker<Stripes<1000, -1000, Cyan, Red,Magenta, Yellow, Blue>, White>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<200>>,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveDragL<BrownNoiseFlickerL<White,Int<300>>,TrWipeIn<400>,TrFade<400>>,ResponsiveMeltL<Mix<TwistAngle<>,Red,Orange>,TrWipeIn<600>,TrSmoothFade<600>>,InOutTrL<TrWipe<300>,TrWipeIn<800>,Black>>>(),
StylePtr<InOutHelper<SimpleClash<Lockup<Blast<AudioFlicker<Stripes<1000, 1000, Cyan, Red,Magenta, Yellow, Blue>, White>,White>,AudioFlicker<AudioFlicker<Stripes<1000, 1000, Cyan, Red,Magenta, Yellow, Blue>, White>,White>>,White>, 300, 800,Pulsing<AudioFlicker<Stripes<1000, 1000, Cyan, Red,Magenta, Yellow, Blue>, White>, Black, 5000>>>(),
{ "Fire", "tracks/bgm2.wav",
StylePtr<InOutHelperX<Lockup<StyleFire<Blast<LocalizedClash<BrownNoiseFlicker<Red,RandomPerLEDFlicker<Rgb<225,0,0>,OrangeRed>,200>,White,80>,White>,Rgb<255,0,0>,0,3,FireConfig<5,1000,1>,FireConfig<0,0,0>,FireConfig<2,1000,5>,FireConfig<100,0,5>>,StyleFire<Pulsing<Gradient<BrownNoiseFlicker<Red,RandomPerLEDFlicker<Rgb<25,0,0>,Rgb<60,0,0>>,200>,BrownNoiseFlicker<Red,RandomPerLEDFlicker<Rgb<25,0,0>,Rgb<60,0,0>>,200>,BrownNoiseFlicker<Red,RandomPerLEDFlicker<Rgb<25,0,0>,Rgb<60,0,0>>,200>,RandomPerLEDFlicker<White,Strobe<Blue,White,50,1>>,BrownNoiseFlicker<Red,RandomPerLEDFlicker<Rgb<25,0,0>,Rgb<60,0,0>>,200>,BrownNoiseFlicker<Red,RandomPerLEDFlicker<Rgb<25,0,0>,Rgb<60,0,0>>,200>,BrownNoiseFlicker<Red,RandomPerLEDFlicker<Rgb<25,0,0>,Rgb<60,0,0>>,200>>,Gradient<BrownNoiseFlicker<Red,RandomPerLEDFlicker<Rgb<25,0,0>,Rgb<60,0,0>>,200>,BrownNoiseFlicker<Red,RandomPerLEDFlicker<Rgb<25,0,0>,Rgb<60,0,0>>,200>,RandomPerLEDFlicker<White,Strobe<Blue,White,50,1>>,BrownNoiseFlicker<Red,RandomPerLEDFlicker<Rgb<25,0,0>,Rgb<60,0,0>>,200>,BrownNoiseFlicker<Red,RandomPerLEDFlicker<Rgb<25,0,0>,Rgb<60,0,0>>,200>,BrownNoiseFlicker<Red,RandomPerLEDFlicker<Rgb<25,0,0>,Rgb<60,0,0>>,200>>,3500>,Rgb<80,0,0>,0,6,FireConfig<10,1000,2>,FireConfig<0,0,0>,FireConfig<2,1000,5>,FireConfig<100,0,5>>,RandomPerLEDFlicker<White,Red>>,InOutFuncX<Int<150>,Int<500>>>>(),
StylePtr<IgnitionDelay<0,InOutHelper<StyleFire<BrownNoiseFlicker<Red,RandomPerLEDFlicker<Rgb<25,0,0>,Rgb<60,0,0>>,200>,Rgb<80,0,0>,0,6,FireConfig<10,1000,2>,FireConfig<0,0,0>,FireConfig<2,1000,5>,FireConfig<100,0,5>>,120,500,Pulsing<Black, Tomato, 2000>>>>(),
StylePtr<Black>(), "KyloRen"}
{ "blaster1", "",
StylePtr<Black>(),
StylePtr<Pulsing<Blue,Black,5000>>(),
StylePtr<Layers<
Black,
TransitionEffectL<TrConcat<TrDelay<100>,Blue,TrFade<200>,Blue,TrFade<300>>,EFFECT_FIRE>,
TransitionEffectL<TrConcat<TrDelay<100>,Blue,TrFade<200>,Blinking<Black,Blue,100,500>,TrFade<300>>,EFFECT_STUN>,
LockupTrL<Layers<
TransitionLoopL<TrConcat<TrInstant,White,TrFade<50>,Blue,TrFade<150>>>>,TrInstant,TrConcat<TrInstant,Blue,TrFade<400>>,SaberBase::LOCKUP_AUTOFIRE>,
TransitionEffectL<TrConcat<TrSmoothFade<500>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<Scale<BatteryLevel,Int<0>,Int<35000>>,Int<-1>>>,TrDelay<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-1>>>,TrSmoothFade<1000>>,EFFECT_BATTERY_LEVEL>
{ NO_BLADE, WS281XBladePtr<133, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3>>(),
WS281XBladePtr<1, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin4> >(),
WS281XBladePtr<1, blade3Pin, Color8::GRB, PowerPINS<bladePowerPin5> >(),
CONFIGARRAY(blaster),
"01_BlasterSave"},
{ 0,WS281XBladePtr<133, bladePin, Color8::GRB, PowerPINS<bladePowerPin6> >(),
CONFIGARRAY(saber),
"00_SaberSave"},
SO CLOSE! everything worked fine with switching the modes and prop like you mentioned. the button works now and I can switch to blaster. the only problem now is the blade doesn’t light up. the leds on the pogo board do, but it doesn’t light up the blade?
I see. the blaster part lights up for both now. instead of igniting the blade, it ignites the blaster led when the blade function is on. any idea how to fix that?
Sounds like you just have to make sure the order of your blade styles match the order of the blades in the BladeConfig. If you don’t know which “blade” is wired to which data pad and power pins, it might be a little of trial and error.
I would make a test preset like
{ "AnyFontNameHere", "",
StylePtr<Red>(),
StylePtr<Green>(),
StylePtr<Blue>(),
"test"}
Then see which blade is which color.
Then you’ll know the order to arrange your styles in. Makes sense?
Clearly, the first one is your main blade, evident due to the number of pixels in the blade definition, but which “1” and “1” are blaster and crystal I couldn’t say.
so, the problem is in the presets, not the config? I’m not getting any light at all in the blade. it has just been redirected into the blaster light. seems like it needs to be redirected to the blade?
should there be three styles in each? can I just make them all the same?
I tried doing that with a preset that I added. I just did a regular blade style three times under one preset. still didn’t light.
thanks a lot for all your help. we got so close. I tried mixing around a couple of the presets with no luck, unfortunately. I won’t take up any more of your time, but if you think of anything else that might work, please let me know. everything works perfectly except the blade lighting up ![]()
Huh? We’re not done until it works or we find what’s broken (hardware).
Did you try the test preset?
