I have uploaded a new config to my saber once before with no issues but today I added 2 new soundfonts to my saber and now my button will only turn my saber on and off I can only turn it on and off and nothing else I have tried other configs and the problem persists
We need a lot more information to be able to help.
Please post your config file.
What does the “version” command say if you run it in the serial monitor?
Kolby_saber_config1.h (41.9 KB)
Serial monitor says my version is v7.13
I’m using Proffie OS version 7.13
what exactly should i look for in serial monitor, what it says when i turn my saber off and on or something else?
Your config file doesn’t have a prop section, which means it’s using the standard saber prop. Is that what you intended?
no its not what i intended how can i fix that ad are props a new addition because I’ve never heard of them?
No, prop files were added in ProffieOS 2.x…
that fixed my problem thank you so much
