Hi! A friend of mine was installing a proffie and didn’t checked his soldering and got a short. A visual inspection shows that this component has burnt:
I loaded up the Ki CAD files, but I just didn’t found the correct code. From layout I assume it is the DMP2075UFDB-7 MOSFET. If so, could I desolder and solder it back? Because it seems so have dual pads on the bottom that I don’t know how to solder back. I will send it to a proffessional, but I want to know if it is the correct component and can be done by hand.
Thanks in advance.
