I am using a Proffieboard V2 with the bluetooth FSC-BT630 module.
It is properly connected and shows up in the app, but when we want to connect it gives an error.
Is this software related, if so how can we fix this problem?
Is it ForceSync app?
Are you using Android?
Have you tried from a computer or an iOS device instead?
I never got it to connect with the Android version Forcesync app.
Yet the ProffieOS Workbench page on mobile did work.
Did you use the FeasyBlue App beforehand?
Check here:
I read that the BT630 has a weaker signal and a less stable connection.
Unfortunately I can’t help much with the ForceSync app.
Have you tried the ProffieOS Workbench?
