Brand new saber emitter not lighting up
Got my second pach store saber delivered today(BMF). They use a removable chassis system and i had a chassis ready to go after getting the default config from them prior to receiving it. I just opened the box and popped the chassis in with a charged battery and the emitter has no light. My blade is still in the mail so i havent tested that yet. Not sure how my default config could be wrong.
PF_2.2_config.h (3.5 KB)
Does this same chassis work in your other hilt? I read through your config and it looks fine at quick glance. Did you even modify/flash the config? If I’m reading correctly it sounds like you pulled it out of the box and popped it in. You might have to reach out to the seller for support as there could be a wiring issue on the connection pins.
Is the chassis fully seated? Watching the video demo it looks like it almost clicks in if you have it going the right direction. This is your second one so you’d know better than I would on how that connection works.
I wish i could test the other hilt but that ones been having a reoccurring issue that i gave up on. Thinking its a design flaw. But yea i flashed the board and matched my sd card to it. Successful flash and i get all my sounds on the blade just no emitter. Just wanted to make sure i checked everything while waiting for a response from the seller.
Brand new sabers should work.
Return it.
