Boot sound bladestyle
Is it possible to have a bladestyle/effect on boot? I’m looking to add a boot.wav file in the first preset of each saber that says the name of that specific saber so when i flick the Killswitch to on it will play the boot file and have little emitter flare or a full blade pulse or something like that, is this doable?
Sure, totally possible. Just use EFFECT_BOOT.
My library has this effect under Battery Level on the Enhancements screen, just choose Passive Battery Monitor option for “Boot” this will show an emitter flare with the current Battery Level (Green = Full, Yellow = Half, Red = Low) when the saber first boots up. You can just modify the effect/color to show something else if you want.
You can test in the library by turning saber off and clicking “Boot” button in previewer.
Briilant I’ll have a play around with that, thank your very much
