I just received my first saber last Tuesday. I’ve built my config and preset, added some fonts and flashed it. Everything was fine.
Last night, I connected the board to computer by micro-USB as usual, and the board just make a short noise. Usually it makes a whole sentence with a LED glowing when I plugged the USB in. Then, I found that my computer didn’t show a notification that the board was connected. When I plugged it again, the chassis didin’t show any voice or LED glowing. I am very sure the kill switch was turned off when I plugged in to the port. It was the first time I touched the saber last night. But now I find that there’s no voice when I plug a USB into the port, turn on the switch on or click the power button after putting the chassis in. I also used another battery and still nothing happed. What should I do?
I have tried the boot+reset or just reset when plugging in several times, but not detected by Arduino nor a connected notification showing up.
I gave it a try to turn the switch on with a battery in and found that the port being hot quickly, not knowing why. There’s no cable plugged in this process.
