Has anyone ever experienced this? So what happens is the audio starts to get staticky, eventually cuts out entirely and then the neopixel connector goes to a solid color, without the blade effects.
Proffieboard v2.2 with “tesku” stamping
Npxl v3
2 switch setup (tactile switches)
Removable battery with high amp killswitch
Volume is set at 1700 with a 28mm 4ohm 3watt speaker.
I’ve already replaced every single component all the way down to the battery tabs. Tried 3 different batteries and they’re all fully charged. The only thing that I haven’t switched out is the board.
Tried five different SD cards all reformatted with all different fonts. Have tried 3 different configs that have worked in other builds.
This one is really stumping me. This build was working all day yesterday, and now out of nowhere this is what I get. Roughly about 2 minutes into the hum is typically when it starts to kick in, static in the speaker first, then just a solid color, sometimes the audio cuts out completely, sometimes it just keeps going.
