Blaster.wav doesnt play
When i hit aux once blaster.wav is silent, then i swing and blst plays.
my folder structure for blaster.wav is a blaster folder with blaster01 - blaster24, when i run serial monitor in arduino it says
EVENT: Aux-Pressed#1 millis=99985
EVENT: Aux-Pressed millis=99985
Battery voltage: 0.21
EVENT: Aux-Released#1 millis=100081
EVENT: Aux-Released millis=100081
EVENT: Aux-Shortclick#1 millis=100081
EVENT: Aux-Shortclick millis=100081
Saving Current PrFound out files: 1-4 using 2 digits in subdirs in Test2
Found in files: 1-5 using 2 digits in subdirs in Test2
Found blst files: 1-5 using 2 digits in subdirs in Test2
Found blaster files: 1-24 using 2 digits in Test2
Found hum files: 1-1 using 2 digits in subdirs in Test2
Done listing effects.
Booster off.
my config is
const unsigned int maxLedsPerStrip = 130;
#define EXTRA_COLOR_BUFFER_SPACE 70
#define VOLUME 3000
#define CLASH_THRESHOLD_G 3
#define PROFFIEOS_MOTION_FREQUENCY 1600
#define IDLE_OFF_TIME 60 * 2 * 1000
#define PLI_OFF_TIME 15 * 60 * 1000
#define SAVE_STATE
#define FETT263_RANDOMIZE_QUOTE_PLAYER
#define FETT263_DISABLE_MULTI_BLAST_TOGGLE
#define FETT263_THRUST_ON
#define FETT263_FORCE_PUSH_LENGTH 0.1
#define ENABLE_SPINS
#define FETT263_CIRCULAR_VOLUME_MENU
#define DISABLE_COLOR_CHANGE
{ "Test2;common",  "Test2/tracks/Songs.wav",
StylePtr<Layers<
Layers<
  Red,
  OriginalBlastL<Green>,
  TransitionEffectL<TrConcat<TrDelay<100>,AlphaL<White,Int<0>>,TrDoEffect<TrInstant,EFFECT_GAME_CHOICE>>,EFFECT_INTERACTIVE_BLAST>,
  TransitionEffectL<TrConcat<TrExtendX<Sum<WavLen<EFFECT_INTERACTIVE_BLAST>,Int<500>>,TrInstant>,TransitionPulseL<TrDoEffect<TrInstant,EFFECT_BLAST>,ThresholdPulseF<SwingSpeed<300>,Int<16000>>>,TrConcat<TrDelay<150>,TrRandom<TrDoEffect<TrInstant,EFFECT_INTERACTIVE_BLAST>,TrInstant,TrDoEffect<TrInstant,EFFECT_INTERACTIVE_BLAST>,TrDoEffect<TrInstant,EFFECT_INTERACTIVE_BLAST>>>>,EFFECT_GAME_CHOICE>,
  InOutTrL<TrInstant,TrInstant>>
Blast effect sounds are blstNN.wav if you have a polyphonic font.
More info here:
I have blst.wav files as well, they are the ones that work. The issue is that in the interactive blast the initial blaster sound before blst.wav is silent. To be more specific i am using the blaster sounds from the extras folder in kyberphonic’s survivor 2 font
Interactive Blast uses blastNN.wav for blaster sound, not blasterNN.wav. blaster.wav is the monophonic version for blst.wav
thanks for the correction, ill correct it right away
