/* Basic blaster prop use.
Default Startup Mode = STUN
Add the following to your config file if so desired:
#define BLASTER_SHOTS_UNTIL_EMPTY 15 (whatever number)
#define BLASTER_JAM_PERCENTAGE if this is not defined, random from 0-100%.
Blaster Buttons: FIRE and MODE
(Blaster is always on with power, unless dedicated Power button is installed.)
Cycle Modes - Click MODE.
Next Preset - Long click and release MODE.
Previous Preset - Double click and hold MODE, release after a second.
Reload - Hold MODE until Reloaded. (Or Click Reload if dedicated button insatlled)
Start/Stop Track - Double click MODE.
Fire - Click FIRE. (Hold to Auto Fire / Rapid Fire)
Clip In - Clip Detect pad Latched On. ( or Hold Momentary button)
Clip out - Clip Detect pad Latched Off. ( or release Momentary button)
Unjam - Bang the blaster.
- If there's a 3rd button for Power,
Power On / Off - Click POWER.
Wavs to use for switching Modes:
mdstun.wav
mdkill.wav
mdauto.wav
- If these are not present, mode.wav will be used for all modes.
- If no mode.wav either, then Talkie voice speaks selected mode.
#ifndef PROPS_BLASTER_H
#define PROPS_BLASTER_H
#include "prop_base.h"
#define PROP_TYPE Blaster
#define PROP_HAS_BULLET_COUNT
EFFECT(clipin);
EFFECT(clipout);
EFFECT(empty);
EFFECT(full);
EFFECT(jam);
EFFECT(mode);
EFFECT(plioff);
EFFECT(plion);
EFFECT(range);
EFFECT(reload);
EFFECT(stun);
EFFECT(unjam);
EFFECT(mdstun);
EFFECT(mdkill);
EFFECT(mdauto);
// For mode sounds, specific "mdstun", "mdkill", and "mdauto" may be used.
// If just a single "mode" sound for all switches exists, that will be used.
// If no mode sounds exist in the font, a talkie version will speak the mode on switching.
class Blaster : public PROP_INHERIT_PREFIX PropBase {
public:
Blaster() : PropBase() {}
const char* name() override { return "Blaster"; }
// Mode states to handle kill vs stun effects
enum BlasterMode {
MODE_STUN,
MODE_KILL,
MODE_AUTO
BlasterMode blaster_mode = MODE_STUN;
virtual void SetBlasterMode(BlasterMode to_mode) {
if (!auto_firing_) {
blaster_mode = to_mode;
SaberBase::DoEffect(EFFECT_MODE, 0);
virtual void NextBlasterMode() {
switch(blaster_mode) {
case MODE_STUN:
SetBlasterMode(MODE_KILL);
return;
case MODE_KILL:
#ifdef ENABLE_BLASTER_AUTO
SetBlasterMode(MODE_AUTO);
#else
SetBlasterMode(MODE_STUN);
return;
case MODE_AUTO:
return;
bool auto_firing_ = false;
int shots_fired_ = 0;
bool is_jammed_ = false;
#ifdef BLASTER_SHOTS_UNTIL_EMPTY
const int max_shots_ = BLASTER_SHOTS_UNTIL_EMPTY;
#else
const int max_shots_ = -1;
virtual int GetBulletCount() {
return max_shots_ - shots_fired_;
virtual bool CheckJam(int percent) {
int random = rand() % 100;
return random < percent;
virtual void Fire() {
#ifdef ENABLE_MOTION
#ifdef BLASTER_JAM_PERCENTAGE
// If we're already jammed then we don't need to recheck. If we're not jammed then check if we just jammed.
is_jammed_ = is_jammed_ ? true : CheckJam(BLASTER_JAM_PERCENTAGE);
if (is_jammed_) {
SaberBase::DoEffect(EFFECT_JAM, 0);
return;
if (max_shots_ != -1) {
if (shots_fired_ >= max_shots_) {
SaberBase::DoEffect(EFFECT_EMPTY, 0);
return;
if (blaster_mode == MODE_AUTO) {
SelectAutoFirePair(); // Set up the autofire pairing if the font suits it.
SaberBase::SetLockup(LOCKUP_AUTOFIRE);
SaberBase::DoBeginLockup();
auto_firing_ = true;
} else {
if (blaster_mode == MODE_STUN) {
SaberBase::DoEffect(EFFECT_STUN, 0);
} else {
SaberBase::DoEffect(EFFECT_FIRE, 0);
shots_fired_++;
virtual void SelectAutoFirePair() {
if (!SFX_auto.files_found() || !SFX_blast.files_found()) return;
int autoCount = SFX_auto.files_found();
int blastCount = SFX_blast.files_found();
int pairSelection;
// If we don't have a matched pair of autos and blasts, then don't override the sequence to get a matched pair.
if (autoCount == blastCount) {
pairSelection = rand() % autoCount;
SFX_auto.Select(pairSelection);
SFX_blast.Select(pairSelection);
virtual void Reload() {
shots_fired_ = 0;
SaberBase::DoEffect(EFFECT_RELOAD, 0);
virtual void ClipOut() {
if (max_shots_ != -1) shots_fired_ = max_shots_;
SaberBase::DoEffect(EFFECT_CLIP_OUT, 0);
virtual void ClipIn() {
SaberBase::DoEffect(EFFECT_CLIP_IN, 0);
// Pull in parent's SetPreset, but turn the blaster on.
void SetPreset(int preset_num, bool announce) override {
PropBase::SetPreset(preset_num, announce);
if (!SFX_poweron) {
if (!SaberBase::IsOn()) {
On();
void LowBatteryOff() override {
if (SFX_poweron) {
PropBase::LowBatteryOff();
// Self-destruct pulled from detonator
bool armed_ = false;
enum NextAction {
NEXT_ACTION_NOTHING,
NEXT_ACTION_ARM,
NEXT_ACTION_BLOW,
NextAction next_action_ = NEXT_ACTION_NOTHING;
uint32_t time_base_;
uint32_t next_event_time_;
void SetNextAction(NextAction what, uint32_t when) {
time_base_ = millis();
next_event_time_ = when;
next_action_ = what;
void SetNextActionF(NextAction what, float when) {
SetNextAction(what, when * 1000);
void PollNextAction() {
if (millis() - time_base_ > next_event_time_) {
switch (next_action_) {
case NEXT_ACTION_NOTHING:
break;
case NEXT_ACTION_ARM:
armed_ = true;
// TODO: Should we have separate ARMING and ARMED states?
break;
case NEXT_ACTION_BLOW:
Off(OFF_BLAST);
break;
void beginArm() {
SaberBase::SetLockup(SaberBase::LOCKUP_ARMED);
#ifdef ENABLE_AUDIO
float len = hybrid_font.GetCurrentEffectLength();
#else
float len = 1.6;
SetNextActionF(NEXT_ACTION_ARM, len);
void selfDestruct() {
SaberBase::DoEndLockup();
#ifdef ENABLE_AUDIO
#else
float len = 0.0;
SaberBase::SetLockup(SaberBase::LOCKUP_NONE);
if (armed_) {
SetNextActionF(NEXT_ACTION_BLOW, len);
} else {
SetNextAction(NEXT_ACTION_NOTHING, 0);
void Loop() override {
PropBase::Loop();
PollNextAction();
// Make clash do nothing except unjam if jammed.
void Clash(bool stab, float strength) override {
if (is_jammed_) {
is_jammed_ = false;
SaberBase::DoEffect(EFFECT_UNJAM, 0);
// Make swings do nothing
void DoMotion(const Vec3& motion, bool clear) override {
PropBase::DoMotion(Vec3(0), clear);
switch (EVENTID(button, event, modifiers)) {
case EVENTID(BUTTON_MODE_SELECT, EVENT_FIRST_SAVED_CLICK_SHORT, MODE_ON):
NextBlasterMode();
return true;
case EVENTID(BUTTON_MODE_SELECT, EVENT_FIRST_CLICK_LONG, MODE_ON):
next_preset();
return true;
case EVENTID(BUTTON_MODE_SELECT, EVENT_SECOND_CLICK_LONG, MODE_ON):
previous_preset();
return true;
case EVENTID(BUTTON_RELOAD, EVENT_PRESSED, MODE_ON):
case EVENTID(BUTTON_MODE_SELECT, EVENT_HELD_MEDIUM, MODE_ON):
Reload();
return true;
case EVENTID(BUTTON_MODE_SELECT, EVENT_DOUBLE_CLICK, MODE_ON):
StartOrStopTrack();
return true;
case EVENTID(BUTTON_FIRE, EVENT_PRESSED, MODE_ON):
Fire();
return true;
case EVENTID(BUTTON_FIRE, EVENT_RELEASED, MODE_ON):
if (SaberBase::Lockup()) {
return true;
case EVENTID(BUTTON_CLIP_DETECT, EVENT_PRESSED, MODE_ON):
case EVENTID(BUTTON_CLIP_DETECT, EVENT_LATCH_ON, MODE_ON):
ClipIn();
return true;
case EVENTID(BUTTON_CLIP_DETECT, EVENT_RELEASED, MODE_ON):
case EVENTID(BUTTON_CLIP_DETECT, EVENT_LATCH_OFF, MODE_ON):
ClipOut();
return true;
// In the event of the presence of a power button, let it control the power on events.
case EVENTID(BUTTON_POWER, EVENT_PRESSED, MODE_OFF):
On();
return true;
case EVENTID(BUTTON_POWER, EVENT_PRESSED, MODE_ON):
Off();
return true;
#ifdef BLADE_DETECT_PIN
case EVENTID(BUTTON_BLADE_DETECT, EVENT_LATCH_ON, MODE_ANY_BUTTON | MODE_ON):
case EVENTID(BUTTON_BLADE_DETECT, EVENT_LATCH_ON, MODE_ANY_BUTTON | MODE_OFF):
// Might need to do something cleaner, but let's try this for now.
blade_detected_ = true;
FindBladeAgain();
return true;
case EVENTID(BUTTON_BLADE_DETECT, EVENT_LATCH_OFF, MODE_ANY_BUTTON | MODE_ON):
case EVENTID(BUTTON_BLADE_DETECT, EVENT_LATCH_OFF, MODE_ANY_BUTTON | MODE_OFF):
blade_detected_ = false;
FindBladeAgain();
SaberBase::DoBladeDetect(false);
return true;
return false;
// Blaster effects, auto fire is handled by begin/end lockup
void SB_Effect(EffectType effect, float location) override {
switch (effect) {
default: return;
case EFFECT_STUN: hybrid_font.PlayCommon(&SFX_stun); return;
case EFFECT_FIRE: hybrid_font.PlayCommon(&SFX_blast); return;
case EFFECT_CLIP_IN: hybrid_font.PlayCommon(&SFX_clipin); return;
case EFFECT_CLIP_OUT: hybrid_font.PlayCommon(&SFX_clipout); return;
case EFFECT_RELOAD: hybrid_font.PlayCommon(&SFX_reload); return;
case EFFECT_MODE: SayMode(); return;
case EFFECT_RANGE: hybrid_font.PlayCommon(&SFX_range); return;
case EFFECT_EMPTY: hybrid_font.PlayCommon(&SFX_empty); return;
case EFFECT_FULL: hybrid_font.PlayCommon(&SFX_full); return;
case EFFECT_JAM: hybrid_font.PlayCommon(&SFX_jam); return;
case EFFECT_UNJAM: hybrid_font.PlayCommon(&SFX_unjam); return;
case EFFECT_PLI_ON: hybrid_font.PlayCommon(&SFX_plion); return;
case EFFECT_PLI_OFF: hybrid_font.PlayCommon(&SFX_plioff); return;
void SayMode() {
switch (blaster_mode) {
case MODE_STUN:
if (SFX_mdstun) {
hybrid_font.PlayCommon(&SFX_mdstun);
} else if (SFX_mode) {
hybrid_font.PlayCommon(&SFX_mode);
} else {
talkie.Say(spSTUN);
break;
case MODE_KILL:
if (SFX_mdkill) {
hybrid_font.PlayCommon(&SFX_mdkill);
} else {
talkie.Say(spKILL);
break;
case MODE_AUTO:
if (SFX_mdauto) {
hybrid_font.PlayCommon(&SFX_mdauto);
} else {
talkie.Say(spAUTOFIRE);
break;
