I went out and got some SMD resistors and opened up a blade I had.
I placed a 47K resistor across the blade side PCB Data and GND pads and soldered it into place. I then measured the resistance (to see if I had soldered it right) and it looked perfect at 47K.
I then snapped the PCB in to the adapter, re-soldered the leads and superglued (big mistake) the base once I had done a quick power up.
I used the scanned command several times between a “fresh” blade and this new one and basically was unable to have any luck - the ID always comes back at ~900.
How should I be selecting BladeID resistors?
BladeID Blade
Welcome to ProffieOS $Id: ce12a06a1e236b5101ec60c950530a9a4719a74d $. Type 'help' for more info.
I2C init..
Motion setup ... done.
Saving Global State
Amplifier off.
Unmounting SD Card.
Battery voltage: 3.43
Battery voltage: 3.42
blade= 1
WS2811 Blade with 144 leds.
Simple Blade
Style RAM = 672
Style RAM = 4
Charging Style
Charging Style
Style RAM = 76
Style RAM = 8
Normal Blade
I2C init..
Saving Global State
Amplifier off.
Unmounting SD Card.
blade= 0
WS2811 Blade with 114 leds.
Simple Blade
Style RAM = 672
Style RAM = 4
Charging Style
Charging Style
Style RAM = 76
Style RAM = 8
a few swaps:
blade= 0
Simple Blade
Style RAM = 672
Style RAM = 4
Charging Style
Charging Style
Style RAM = 76
Style RAM = 8
Scanning sound font: LS6 done
Scanning sound font: common done
Activating polyphonic font.
Activating SmoothSwing V2
Accent Swings NOT Detected:
Unmounting SD Card.
Amplifier off.
Unmounting SD Card.
blade= 0
Simple Blade
Style RAM = 672
Style RAM = 4
Charging Style
Charging Style
Style RAM = 76
Style RAM = 8
Unmounting SD Card.
blade= 0
Simple Blade
Style RAM = 672
Style RAM = 4
Charging Style
Charging Style
Style RAM = 76
Style RAM = 8
Unmounting SD Card.
EVENT: Clash millis=103504
EVENT: Stab millis=107340
EVENT: Stab millis=109026
blade= 0
Simple Blade
Style RAM = 672
Style RAM = 4
Charging Style
Charging Style
Style RAM = 76
Style RAM = 8
blade= 1
Simple Blade
Style RAM = 672
Style RAM = 4
Charging Style
Charging Style
Style RAM = 76
Style RAM = 8
I2C init..
Saving Global State
Amplifier off.
Unmounting SD Card.
blade= 0
Simple Blade
Style RAM = 672
Style RAM = 4
Charging Style
Charging Style
Style RAM = 76
blade= 0
Simple Blade
Style RAM = 672
Style RAM = 4
Charging Style
Charging Style
Style RAM = 76
Style RAM = 8
blade= 0
Simple Blade
Style RAM = 672
Style RAM = 4
Charging Style
Charging Style
Style RAM = 76
Style RAM = 8
blade= 0
Simple Blade
Style RAM = 672
Style RAM = 4
Charging Styl
Charging Style
Style RAM = 76
Style RAM = 8
