Hello I am new to Proffie. We just recently purchased a Starkiller Saber from Nsabers with a neopixel blade. it has a Proffie 2.2 in the hilt. I was able to follow some instructions to update it to OS6 online. everything was working fine but we are fairly new with now to the new menu system from Fet263.
My son was playing with the saber and he said that he accidentally turned off the motion settings (said something about motion off) so he unscrewed the hilt and pulled out the module while it was still on. he handed me the module only and I turned it off. While putting the module back into the hilt and trying to turn it on the neopixal blade won’t light up anymore.
The hilt seems to be working properly and the crystal chamber along with where the blade plugs in seems to be lighting up just fine but the blade itself is not working. I am wondering if you think my son damaged the blade and I need a new blade or if something is turned off in the settings. if you can give me some advice it would be really helpful thank you!
I currently don’t have another blade to test with right now. It does not light up the blade at all. it does light up the hilt and the crystal chamber, just not the blade itself
So, it’s not particularly easy to tell if the problem is in the blade or in the hilt. You would need a multimeter, and then make sure that the blade is getting data and power from the hilt.
Since you have a removable chassis, there is also a reasonably good chance that the problem is in the chasis ↔ hilt connection.
Basically, your options are:
use a multimeter to find out where the problem is. ($)
buy a new blade and hope it works ($$)
ask the people who installed it to fix it for you ($$$)
buy a new one ($$$$)
give up, go join a commune and give up all earthly possessions (free)
