Not sure if there’s a topic for this already or if it’s already available but I haven’t found it yet. But wanted to suggest if there could be a blade style, that would react such as turn on or off on button events.
The use case I have is for Electrum touch clamp cards. When the user taps one of the touch buttons, the accent LEDs near that capacitive touch button would light up.
So if I tap the switch defined for BUTTON_POWER it would trigger an event that the blade style could listen in on and turn on/off, or other animated effects.
I know that for regular switches this could work by wiring the switch and accent LED in series. But with touch buttons only needing 1 wire I’m not sure if that idea holds.
