Blade Style optimization?
Tips on how to optimize this for os7?
Ultron
StylePtr<Layers<
  StyleFire<StripesX<Int<3000>,Scale<SlowNoise<Int<2000>>,Int<-1000>,Int<-5000>>,BrownNoiseFlicker<RotateColorsX<Variation,DarkOrange>,Black,100>,Strobe<Black,Blue,15,100>,RotateColorsX<Variation,Rgb<255,59,25>>,RotateColorsX<Variation,Rgb<128,34,0>>>,RotateColorsX<Variation,Rgb<80,11,0>>,0,5,FireConfig<3,3000,0>,FireConfig<3,3000,0>,FireConfig<3,3000,0>,FireConfig<3,3000,0>>,
  AlphaL<AudioFlickerL<White>,SwingSpeed<600>>,
  LockupTrL<Layers<
    AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
    AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrJoinR<TrWipe<100>,TrWipeIn<100>>,White,TrJoinR<TrWipe<100>,TrWipeIn<100>>>,SaberBase::LOCKUP_NORMAL>,
  ResponsiveStabL<Red>,
  ResponsiveBlastWaveL<White,Int<300>,Int<100>,Int<300>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,EFFECT_CLASH>,
  InOutTrL<TrWipe<300>,TrWipeIn<500>>,
  TransitionEffectL<TrConcat<TrFade<100>,AlphaL<HumpFlickerL<Red,10>,Bump<Int<0>,Int<4000>>>,TrFade<100>,AlphaL<HumpFlickerL<Orange,15>,Bump<Int<0>,Int<5000>>>,TrFade<100>,AlphaL<HumpFlickerL<White,20>,Bump<Int<0>,Int<6000>>>,TrBoing<1000,3>>,EFFECT_PREON>>>()
Also, how do i make it where if i have a blade effect when i swing, it stops the moment i stop swinging instead of fading away?
What do you want to optimize for? Less memory?
Does it currently work?
yea it works. I just want to know if theres any way for it to use less memory with os7
Short answer: no
Long answer: It might be possible, but reducing memory without changing functionality is complicated and takes time. Also, it depends heavily on what the other presets in the config file have. Having similar styles tends to reduce memory usage. You’re better off looking for other ways to save memory.
alright. Do you know about the other question i had
