I would like to create a custom lightsaber style, or at least one I don’t see existing currently. This style would be very similar to the style that already exists in the 9th Jedi: Kara style. (The way I am able to understand it,) This style is interactive in that it counts the number of clashes, then has a triggering mechanism in the form of a lockup, that results in the blade changing colors.
Ideally what I would like to do is just make use of Fett263’s style library to construct a style that does the following:
- If possible include some mechanism that counts swing numbers
- Trigger a color change at 5 swings
- Trigger a separate color change at 10 swings
Any help, or other ideas/options are greatly appreciated. Thanks for your time in advance.
