Anyone got a good quality group who does this?
Blades are not typically sold this way, as it’s a personal setup depending on what other blades it needs to play with.
That said, it’s literally just soldering a resistor across the data pin and GND.
I thought the blade also needed a resistor though?
It’s sometimes possible to do without, but it’s better if you have one.
Don’t confuse data resistor with Blade ID resistor ![]()
Yeah sounds like I have to build one - the two blades I have are nicely superglued together.
