I recently finished a Goth-3Designs Graflex grand master chassis install and am trying to get blade ID to cooperate. I tried originally with OS7.14 but the define for blade id scan wasnt working. So I downloaded the master OS and it started working correctly. Sadly, for whatever reason the pixels inside the removable crystals are now blinking every second and dimmer than they should be causing the color to be incorrect at times. such as orange becomes a dim red.
on a fresh bootup the crystal starts at the correct brightness for the first second until what I assume is the scanning commencing. Not sure why this is happening. any ideas? Config attached below.
// Grand Master Chassis: Using NO_BLADE to simply allow for bladein and bladeout.wavs to play,
// while also using the NPXL emitter PCB at full length of only 16 pixels when no blade is inserted.
// All presets, fonts, and blade styles shared between the 2 states.
// Note: resistance value needs to be measured in serial monitor to enter values for NO_BLADE_ID_RANGE define as well as actual blade in BladeConfig.
#define NUM_BLADES 6
#define VOLUME 2500
#define CLASH_THRESHOLD_G 3.5
#define ENABLE_SSD1306
#define SAVE_STATE
#define FETT263_TWIST_ON
#define FETT263_RANDOMIZE_QUOTE_PLAYER
// Use with Blade ID. Specify the LED pad(s) that the main blade uses.
#define ENABLE_POWER_FOR_ID PowerPINS<bladePowerPin1>
// Required when blades on different data pads use common LED power pads.
// and/or when BLADE_ID_SCAN_MILLIS is used with Blade ID.
//#define SHARED_POWER_PINS
// Choose how often to check for new blade (milliseconds).
// Larger values will be a longer delay before a blade is recognized.
// How many Blade ID scans to average (default is 10, 15 works well)
#define BLADE_ID_TIMES 15
// Measured value range to return as NO_BLADE (use NO_BLADE as the blade definition value.)
#define NO_BLADE_ID_RANGE 600000,999999999
Preset light[] = {
{ "Graflex ANH;common", "/Graflex ANH/tracks",
//blade
StylePtr<Layers<
Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<24000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-1400>,Int<-100>>,RgbArg<BASE_COLOR_ARG,Rgb<0,40,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,40,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,40,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,40,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,40,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,40,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,40,255>>>,
TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RgbArg<IGNITION_COLOR_ARG,White>>,TrFade<1200>>,EFFECT_IGNITION>,
TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,White>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,
LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,White>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,White>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,White>,AudioFlicker<RgbArg<LB_COLOR_ARG,White>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,White>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,White>,TrFade<400>>>,
LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,White>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,White>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG>,
LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,
InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<>,Mult<IntArg<IGNITION_OPTION2_ARG,18992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<>,Mult<IntArg<RETRACTION_OPTION2_ARG,7992>,Int<98304>>>>>>>(),
//arc reactor
StylePtr<Layers<
Pulsing<Mix<Int<8192>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,80,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,80,255>>,2000>,
TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,White>,Scale<WavLen<>,Int<100>,Int<400>>,Int<100>,Scale<WavLen<>,Int<100>,Int<400>>,Int<0>>,EFFECT_BLAST>,
Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,White>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<0>>,EFFECT_CLASH>,AlphaL<White,Int<0>>>,
LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,White>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,White>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,31000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG>,
LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,
InOutTrL<TrFadeX<BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrFadeX<BendTimePowInvX<RetractionTime<1200>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Pulsing<Mix<Int<8192>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,80,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,80,255>>,8000>>>>(),
//crystal
StylePtr<Layers<
InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Pulsing<Black,RgbArg<BASE_COLOR_ARG,Rgb<0,40,255>>,8000>>>>(),
//oled accents
StylePtr<Layers<
Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<0,40,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,40,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,40,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,40,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,40,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,40,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,40,255>>>,
TransitionEffectL<TrConcat<TrJoin<TrDelay<30>,TrInstant>,RgbArg<BLAST_COLOR_ARG,White>,TrFade<300>>,EFFECT_BLAST>,
TransitionEffectL<TrConcat<TrJoin<TrDelay<30>,TrInstant>,RgbArg<CLASH_COLOR_ARG,White>,TrFade<300>>,EFFECT_CLASH>,
LockupTrL<TransitionEffect<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,White>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,White>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
LockupTrL<Strobe<RgbArg<LB_COLOR_ARG,White>,AudioFlicker<RgbArg<LB_COLOR_ARG,White>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,White>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,White>,TrFade<400>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,
InOutTrL<TrConcat<TrFadeX<BendTimePowInvX<IgnitionTime<1200>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,Red,TrFadeX<BendTimePowInvX<IgnitionTime<1200>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,DarkOrange,TrFadeX<BendTimePowInvX<IgnitionTime<1200>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,White,TrFadeX<BendTimePowInvX<IgnitionTime<1200>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>>,TrConcat<TrFadeX<BendTimePowInvX<RetractionTime<800>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,White,TrFadeX<BendTimePowInvX<RetractionTime<800>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,DarkOrange,TrFadeX<BendTimePowInvX<RetractionTime<800>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Red,TrFadeX<BendTimePowInvX<RetractionTime<800>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>>,Pulsing<Black,RgbArg<BASE_COLOR_ARG,Rgb<0,40,255>>,8000>>>>(),
//speaker led
StylePtr<Red>(),
//motor
StyleNormalPtr<Rgb<200,0,0>,WHITE,300,800>(),
"graflex\nanh"},
Preset dark[] = {
{ "Father ANH;common", "/Father ANH/tracks",
//blade
StylePtr<Layers<
Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<14000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-4000>,Int<-400>>,RgbArg<BASE_COLOR_ARG,Red>,RgbArg<BASE_COLOR_ARG,Red>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Red>>,RgbArg<BASE_COLOR_ARG,Red>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Red>>>,RgbArg<BASE_COLOR_ARG,Red>>,RgbArg<BASE_COLOR_ARG,Red>>,
TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RgbArg<IGNITION_COLOR_ARG,White>,40>,TrFade<1200>>,EFFECT_IGNITION>,
LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,White>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>,RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,White>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,White>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,White>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,White>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,DarkOrange>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,DarkOrange>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,
InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<>,Mult<IntArg<IGNITION_OPTION2_ARG,7992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<>,Mult<IntArg<RETRACTION_OPTION2_ARG,19992>,Int<98304>>>>>>>(),
//arc reactor
StylePtr<Layers<
Pulsing<Black,RgbArg<BASE_COLOR_ARG,Red>,2000>,
InOutTrL<TrFadeX<BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrFadeX<BendTimePowInvX<RetractionTime<1200>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Pulsing<Black,RgbArg<BASE_COLOR_ARG,Red>,8000>>>>(),
//crystal
StylePtr<Layers<
Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Red>,RgbArg<BASE_COLOR_ARG,Red>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Red>>,RgbArg<BASE_COLOR_ARG,Red>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Red>>>,RgbArg<BASE_COLOR_ARG,Red>>,RgbArg<BASE_COLOR_ARG,Red>>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<LOCKUP_COLOR_ARG,White>,SmoothStep<ClashImpactF<>,Int<-4000>>>,TrFadeX<Scale<ClashImpactF<>,Int<100>,Int<300>>>>,EFFECT_LOCKUP_BEGIN>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<LOCKUP_COLOR_ARG,White>,Int<0>>,TrSelect<Scale<IsLessThan<ClashImpactF<>,Int<20000>>,Int<1>,Int<0>>,TrWaveX<RgbArg<LOCKUP_COLOR_ARG,White>,Scale<ClashImpactF<>,Int<50>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<500>,Int<300>>,Int<0>>,TrSparkX<Stripes<1200,-3600,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>,RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>,Int<30>,Scale<Sum<ClashImpactF<>,SwingSpeed<600>>,Int<100>,Int<400>>,Int<0>>>>,EFFECT_LOCKUP_END>,
LockupTrL<AlphaL<RgbArg<LB_COLOR_ARG,White>,Int<0>>,TrInstant,TrConcat<TrInstant,Strobe<RgbArg<LB_COLOR_ARG,White>,AudioFlicker<RgbArg<LB_COLOR_ARG,White>,Blue>,50,1>,TrFade<1000>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,
InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,TransitionLoop<RgbArg<BASE_COLOR_ARG,Red>,TrConcat<TrBoing<1200,2>,Mix<Int<1285>,Black,RgbArg<BASE_COLOR_ARG,Red>>,TrFade<1200>>>>>>(),
//oled accents
StylePtr<Layers<
//speaker led
StylePtr<Red>(),
//motor
"vader\nanh"},
Preset noblade[] = {
{ "Calibrate;common", "/Calibrate/tracks",
//blade
StylePtr<Layers<
Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<200,200,255>>,RgbArg<BASE_COLOR_ARG,Rgb<200,200,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<200,200,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<200,200,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<200,200,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<200,200,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<200,200,255>>>,
InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<>,Mult<IntArg<IGNITION_OPTION2_ARG,5992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<>,Mult<IntArg<RETRACTION_OPTION2_ARG,6992>,Int<98304>>>>>>>(),
//arc reactor
StylePtr<Layers<
Layers<
Mix<Int<8192>,Black,RgbArg<BASE_COLOR_ARG,AliceBlue>>,
PulsingL<RgbArg<BASE_COLOR_ARG,AliceBlue>,Int<2000>>>,
TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RgbArg<IGNITION_COLOR_ARG,AliceBlue>>,TrFade<1200>>,EFFECT_IGNITION>,
SparkleL<RgbArg<EMITTER_COLOR_ARG,AliceBlue>,50,300>,
InOutTrL<TrCenterWipeX<BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,5992>,Int<98304>>>>,TrJoin<TrCenterWipeInX<BendTimePowInvX<RetractionTime<>,Mult<IntArg<RETRACTION_OPTION2_ARG,20992>,Int<98304>>>>,TrSmoothFadeX<BendTimePowInvX<RetractionTime<>,Mult<IntArg<RETRACTION_OPTION2_ARG,20992>,Int<98304>>>>>,Sparkle<Black,PulsingL<AliceBlue,Int<3000>>,700,150>>>>(),
//crystal
StylePtr<Black>(),
//oled accents
StylePtr<Black>(),
//speaker led
StylePtr<Red>(),
//motor
StylePtr<Black>(),
"calibrate"},
{ NO_BLADE,
//blade
SubBlade(1, 133, WS281XBladePtr<134, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >()),
//arc reactor
SubBlade(0, 0, NULL),
//crystal
WS281XBladePtr<1, bladePin, Color8::GRB, PowerPINS<bladePowerPin1> >(),
//oled accents
WS281XBladePtr<6, blade4Pin, Color8::GRB, PowerPINS<bladePowerPin5> >(),
//speaker led
SimpleBladePtr<CH1LED,NoLED, NoLED, NoLED,bladePowerPin4, -1,-1,-1>(),
//motor
SimpleBladePtr<CH1LED,NoLED, NoLED, NoLED,bladePowerPin6, -1,-1,-1>(),
CONFIGARRAY(noblade) },
{ 10490, // Needs to be obtained by running `scanid` in Serial Monitor with blade inserted. Enter average, rounded value.
//blade
//arc reactor
//crystal
//oled accents
//speaker led
//motor
CONFIGARRAY(light) },
{ 32844, // Needs to be obtained by running `scanid` in Serial Monitor with blade inserted. Enter average, rounded value.
//blade
//arc reactor
//crystal
//oled accents
//speaker led
//motor
CONFIGARRAY(dark) },
