Blade Doesn't Light Up Completely
I looked around for an answer to this and couldn’t find one. Among other problems I’m having with the Sabertrio I recently bought off eBay, for some reason when I light up the saber, it only lights up about 90% of the blade. So I went into the config file and saw that it was set to 144 LEDs. I thought then that I just need to increase the number, so I entered 250, just as a guess.
That didn’t work, so I entered 500. The blade is still too short. Am I missing something? Here’s my config:
// Sabertrio Proffie Saber - Blade & Sound Font Configuration
#define NUM_BLADES 4
#define VOLUME 250
const unsigned int maxLedsPerStrip = 250;
#define CLASH_THRESHOLD_G 3.4
#define ENABLE_SSD1306
#define IDLE_OFF_TIME 60*2*1000
#define MOTION_TIMEOUT 60*10*1000
#define SHARED_POWER_PINS
#define BLADE_DETECT_PIN 17
#define SAVE_PRESET
#include"../props/s3button_config.h"
Preset no_blade[] = {
   { "0-NO_BLADE","",
    StylePtr<Black>(),
	StylePtr<Black>(),
	StylePtr<Black>(),
	StylePtr<Pulsing<White,Black,1200>>()
   Preset blade[] = {
	  { "1-Assassin;common", "common/tracks/mars.wav",
    StylePtr<Layers<
  HumpFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,128,0>>,50>,
  //Green humpflicker
  AlphaL<Stripes<2500,-2750,RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<25,60,0>>,Pulsing<RotateColorsX<Variation,Rgb<0,30,0>>,Black,800>>,SwingSpeed<375>>,
  //Swing effect, rippling green
  LockupTrL<Layers<
    AlphaL<AudioFlickerL<Rgb<255,240,80>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
    AlphaL<LemonChiffon,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
  //Responsive lockup
  //Responsive lightning block
  AlphaL<RotateColorsX<Variation,Rgb16<21301,65535,0>>,SmoothStep<Scale<SlowNoise<Int<2500>>,Int<1000>,Int<3000>>,Int<-4000>>>,
  //Sparking emitter flare
  ResponsiveStabL<Red>,
  //Responsive stab
  //Responsive clash
  TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,Rgb16<38402,65535,3934>>,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb16<38402,65535,3934>>,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<500>>,EFFECT_IGNITION>,
  //Unstable ignition
  TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RotateColorsX<Variation,Rgb16<54757,65535,0>>>,TrFade<1000>>,EFFECT_RETRACTION>,
  //Bright retraction
  //Drag
  //Responsive melt
  InOutTrL<TrWipeSparkTip<White,250>,TrWipeInSparkTip<White,656>>,
  //Spark tip ignition and retraction
  TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrDelay<2000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<1000>>,EFFECT_BATTERY_LEVEL>
 { 0, WS281XBladePtr<115, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
  WS281XBladePtr<20, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin4> >(),
    WS281XBladePtr<20, blade4Pin, Color8::GRB, PowerPINS<bladePowerPin5> >(),
    SimpleBladePtr<CreeXPE2WhiteTemplate<550>, NoLED, NoLED, NoLED, bladePowerPin1, -1, -1, -1>()
  , CONFIGARRAY(blade) },
 { NO_BLADE, WS281XBladePtr<115, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
  , CONFIGARRAY(no_blade) },
That is not how you change blade length go back to
Look at bottom of config for BladeConfig section
BladeConfig blades = {
{ 0, WS281XBladePtr<144
This ‘144’ value is blade length.
needs to be at 144 unless you have some special leds. I don’t think it is your case.
115 is the number you want to increase. try 125
You can also temporarily use this as one of your presets:
   { "common", ""
    // === Main Blade Length Finder: === Change the blade config to 144 LEDs: WS281XBladePtr<144,bladePin,Color8::GRB,PowerPINS<bladePowerPin2,bladePowerPin3>>(),
    // https://pod.hubbe.net/howto/how-many-leds-does-my-blade-have.html
    StylePtr<LengthFinder<>>(),
    StylePtr<Black>(),
    StylePtr<Black>(),
    StylePtr<Black>(),
    "length\nfinder"},
Edit: just to have the correct link to the POD:
Thanks guys that worked! :smiley: I just had to increase the number.
