Hello all,
I’m planning a Goth Grand Master build that I would like to switch fonts based on:
- Crystal 1
- Crystal 2
- No crystal
Generally behaving in this manor:
https://www.instagram.com/p/B_x67VYgpwi/?utm_source=ig_web_copy_link
I understand that I can add resistors to the crystals with blade id to handle the font switching and I think I’ve got a handle on that, but I would also like to utilize blade detect to use the in out sounds of the crystal being inserted/removed.
What I’m not clear on is how I would wire up the crystal for blade detect. I understand that normally blade detect works on the npxl pcb by sending that pin to ground when a blade is inserted. So I need to use one of the pins on the crystal/chamber to send that to ground instead?
Any help is appreciated.
