Blade Assistance
Any chance anyone could remove the Sparkle from when the Force Effect is activated? Beyond me for sure.
SBob Blade
this should do it, i moved the sparkles to before the force effects, seems to of done the trick
StylePtr<Layers<
  StripesX<Scale<IsLessThan<BladeAngle<>,Int<16384>>,Scale<BladeAngle<>,Int<20000>,Int<10000>>,Scale<BladeAngle<>,Int<10000>,Int<20000>>>,Scale<BladeAngle<>,Int<-1000>,Scale<IsGreaterThan<HoldPeakF<SwingAcceleration<>,Scale<HoldPeakF<SwingAcceleration<>,Int<200>,Int<4000>>,Int<100>,Int<600>>,Scale<BladeAngle<>,Int<3000>,Int<6000>>>,Int<16384>>,Int<1000>,Int<-1000>>>,StripesX<Int<1500>,Scale<SlowNoise<Int<2500>>,Int<-3000>,Int<-5000>>,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>,Mix<Int<2570>,Black,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>,Mix<Int<16384>,Black,StaticFire<BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,DeepSkyBlue>,RandomPerLEDFlicker<Mix<Int<3213>,Black,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>>,300>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>,0,6,10,1000,2>>,Mix<Int<10280>,Black,StripesX<Int<1500>,Scale<SlowNoise<Int<2500>>,Int<-3000>,Int<-5000>>,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>,Mix<Int<2570>,Black,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>>,Mix<Int<25700>,Black,StaticFire<BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,DeepSkyBlue>,RandomPerLEDFlicker<Mix<Int<3213>,Black,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>>,300>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>,0,6,10,1000,2>>,Mix<Int<7710>,Black,StripesX<Int<1500>,Scale<SlowNoise<Int<2500>>,Int<-3000>,Int<-5000>>,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>,Mix<Int<2570>,Black,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>>>,
  AlphaL<StaticFire<Stripes<12000,-2000,RgbArg<SWING_COLOR_ARG,Rgb<100,100,150>>,RotateColorsX<Int<200>,RgbArg<SWING_COLOR_ARG,Rgb<100,100,150>>>>,Mix<Int<16384>,Black,RgbArg<SWING_COLOR_ARG,Rgb<100,100,150>>>,0,3,2,2000,8>,SmoothStep<Scale<HoldPeakF<Ifon<Scale<IsGreaterThan<SwingSpeed<500>,Int<16000>>,Int<2000>,SwingSpeed<300>>,Int<0>>,Scale<SwingAcceleration<>,Int<100>,Int<600>>,Scale<SwingAcceleration<>,Int<10000>,Int<4000>>>,Int<1000>,Int<40000>>,Int<-4000>>>,
  SparkleL<Magenta,50>,
  SparkleL<Blue,50>,
  SparkleL<Yellow,50>,
  SparkleL<Green,50>,
  SparkleL<DarkOrange,50>,
  ColorSelect<IncrementWithReset<EffectPulseF<EFFECT_FORCE>,ThresholdPulseF<IncrementWithReset<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_STAB>>,EffectPulseF<EFFECT_FORCE>,Int<32768>,Scale<ClashImpactF<>,Int<3000>,Int<14000>>>,Int<32600>>,Int<1>>,TrSmoothFadeX<Int<2000>>,AlphaL<RgbArg<BASE_COLOR_ARG,DeepSkyBlue>,Int<0>>,RgbArg<BASE_COLOR_ARG,DeepSkyBlue>>,
  ColorSelect<IncrementWithReset<EffectPulseF<EFFECT_FORCE>,ThresholdPulseF<IncrementWithReset<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_STAB>>,EffectPulseF<EFFECT_FORCE>,Int<32768>,Scale<ClashImpactF<>,Int<3000>,Int<14000>>>,Int<32600>>,Int<1>>,TrSelect<IncrementWithReset<EffectPulseF<EFFECT_FORCE>,Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_STAB>>,Int<1>>,TrSmoothFadeX<Int<3000>>,TrWipeSparkTipX<BrownNoiseFlicker<RgbArg<SWING_COLOR_ARG,Rgb<100,100,150>>,White,200>,WavLen<EFFECT_FORCE>>>,AlphaL<RgbArg<BASE_COLOR_ARG,DeepSkyBlue>,Int<0>>,StyleFire<StripesX<Int<3000>,Scale<TwistAngle<>,Int<-500>,Int<0>>,Red,Orange,Yellow,Green,Blue,Magenta>,StripesX<Int<3000>,Scale<TwistAngle<>,Int<-500>,Int<0>>,Tomato,OrangeRed,Orange,Yellow,SteelBlue,DeepPink>,0,3,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>>>,
  TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<0>>,TrInstant>,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<100,100,150>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<100,100,150>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<100,100,150>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<100,100,150>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<100,100,150>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<100,100,150>>>>>,TrFade<800>>,EFFECT_IGNITION>,
  TransitionEffectL<TrConcat<TrJoin<TrDelayX<RetractionTime<>>,TrInstant>,Stripes<3000,-3500,RgbArg<RETRACTION_COLOR_ARG,Rgb<100,100,150>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<100,100,150>>>,Black>,BrownNoiseFlicker<RgbArg<RETRACTION_COLOR_ARG,Rgb<100,100,150>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<100,100,150>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<100,100,150>>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<100,100,150>>>>>,TrFade<800>>,EFFECT_RETRACTION>,
  TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,White>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,
  LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,White>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>,RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,White>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,White>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
  LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,White>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,White>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
  LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,
  InOutTrL<TrWipeX<IgnitionTime<0>>,TrWipeX<RetractionTime<>>>,
  TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RgbArg<POSTOFF_COLOR_ARG,Rgb<100,100,150>>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,IntArg<EMITTER_SIZE_ARG,2000>,Sum<IntArg<EMITTER_SIZE_ARG,2000>,Int<3000>>>,Int<-4000>>>,TrDelayX<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>>>,EFFECT_POSTOFF>>>()
Thank you, sir. I’ll give it a go this evening.
Perfection, sir. Many thanks.
Your welcome
