I’m installing my own Desert Wanderer, which is an OWK thin neck (my first and prob only) using the Goth3d Eco CC Chassis (also my first “real” chassis) and I’m trying to figure out how to set up the blade array. I can report that everything is assembled loosely, ready to be glued, and only the board has to be wired with no melted plastic. Having never seen a Goth3D chassis IRL, I am a little amazed. Thanks to all of the installers here who generously share wiring tips!
Since the chassis is removable and it’s a thin neck, the emitter pcb only gets one data line, but it’s a shtok V3 NPXL connector and I’d like tp preserve that cool set up that comes from the V3 configuration generator.
I think I need 6 blades total, power on bladePowerPin2 and 3 for everything (the CC power lines are connected to the chassis NPXL connector), and all 3 data pins (with one external resistor for the CC).
Does this starter config, partcularly the blade array, make sense? It compiles without issue:
//Desert Wanderer
#define NUM_BLADES 6
#define VOLUME 1000
#define CLASH_THRESHOLD_G 1.0
#define SHARED_POWER_PINS
{ "TeensySF;common", "common/tracks/venus.wav",
StyleNormalPtr<CYAN, WHITE, 300, 800>(), "cyan"}
{ 0,
//16 LED Emitter PCB in series with 125 LED Main Blade
// PCB
SubBladeWithStride(0, 15, 2, WS281XBladePtr<141, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >()),
//Main Blade
SubBlade (16, 140, NULL),
//Interior Chassis PCB, Seperate Data
//2 Pixel CC, Seperate Data
WS281XBladePtr<2, blade3Pin, Color8::GRB, PowerPINS<bladePowerPin2,bladePowerPin3> >(),
CONFIGARRAY(presets) },
Thank you!
