Best way to add blinking accent LEDs using Fett 263 style generator?
I have 2 accent LEDs on data2. I want to make them blink individually, on then off in sequence.
Currently using a simple static blade style, with slow run forward when off, and fast run forward when activated.
Is there a better option that will make them more blinky and less like a running sweep effect? Any way to add color changing into the mix? Or is it a limit because of them sharing the single data line?
Easiest would be to do them as SubBlades with 1 pixels each, then do one with “Blinking On-Off” style and the other in “Blinking Off-On”. They would be “roughly” opposite each other.
You can also try “K.I.T.T. Scanner” or one of the “Rotating Section” options.
Otherwise you probably need to build something custom.
Ok, guess it’s time to learn sub blades. I’ll get to reading. If I do them as such, I would be able to control the color on them individually as well?
Yes, as long as you use color Arguments and not a fixed color.
Groovy, got some learning to do. Thank you.
You’re welcome
