So I just wrapped up my first Proffie install, but I just have one more thing to fix: applying Blade Styles to my button. I’m using a 12mm Illuminated momentary switch with a blue LED rated at 3v, 20mA and I threw a 220ohm resistor on it for good measure.
I currently have it installed between 3.3v and LED1, but it appears to be staying on as long as the battery is inserted. It could be because I haven’t applied added LED1 as a blade, but that is where I’m stuck.
Would anyone happen to have a code snippet that they’ve used on an AV switch like mine? Here is my current Pixel blade config:
Any help would be appreciated.
