I’ve read some of the earlier feed regarding this topic… but hope i can get some specific help.
I have lagging and bad coloring due to underperforming SD card in my Pach Store Proffie saber. I used Arduino to note the under performance. Can someone, via a link, send me the brand name.
/stats on a top performing SD Card? Also, wold i need to format it before dumping my fonts onto it and flashing it to the board?
Thanks! I’ve had the saber for two years. Learned a lot about Proffie. Still learning.
I always format when loading on fonts. The main reason not to is to keep any saved changes from edit mode or workbench, which I tend not to use preferring the trimmed down settings menu.
Good luck and let us know if the card is fast and stable
I pick and choose fonts for each saber update. I know some folks like to have their collection available and use much bigger cards, but I realized I’ve never gone over 6 gigs.
Yes. Testing now and it’s running great with multiple back to back boots to be sure the card is found. Early access and public Fett263 features also running smoothly, although I do have questions which will go in the right spot
*CORRECTION/EDIT: Apparently OEMPC and Kioxia no longer offer the Kioxia UHS3 in 16gb, guess I’m going back to Kingston. Go with the UHS3 spec, it’s worth the mild added cost.
re: I’ve not tried the most recent batch of Kingston SDs in maybe 5 months but they are always a solid goto. Same as the Kioxia Exceria. Kioxia = Toshiba.
EDIT DigiKey has decent pricing for the Kingston..
