DId recent changes to sound_library maybe do something to the calculation for say SAY_WHOLE or something?
100% battery (4.15 volts) shows and speaks voltage correctly,
but percentage is spoken as 20% while showing the correct 100%.
Volts first:
sound_library_.SayNumber(battery_monitor.battery(), SAY_DECIMAL);
sound_library_.SayVolts();
PVLOG_NORMAL << "Battery Voltage: " << battery_monitor.battery() << "\n";
01:01:36.722 β Battery Voltage: 4.15
01:01:37.889 β unit = 0 vol = 0.50, Playing ProffieOS_Voicepack_Skoll/common/mnum/mnum4.wav
01:01:37.924 β channels: 1 rate: 44100 bits: 16
01:01:38.389 β Playing mpoint.wav, channels: 1 rate: 44100 bits: 16
01:01:38.852 β unit = 0 vol = 0.50, Playing ProffieOS_Voicepack_Skoll/common/mnum/mnum1.wav
01:01:38.889 β channels: 1 rate: 44100 bits: 16
01:01:39.314 β unit = 0 vol = 0.50, Playing ProffieOS_Voicepack_Skoll/common/mnum/mnum4.wav
01:01:39.347 β channels: 1 rate: 44100 bits: 16
01:01:39.770 β Playing mvolts.wav, channels: 1 rate: 44100 bits: 16
But then percentage is:
sound_library_.SayNumber(battery_monitor.battery_percent(), SAY_WHOLE);
sound_library_.SayPercent();
PVLOG_NORMAL << "Battery Percentage: " <<battery_monitor.battery_percent() << "%\n";
01:01:41.460 β Battery Percentage: 100.00%
01:01:41.460 β Playing battlevl.wav, channels: 1 rate: 44100 bits: 16
01:01:41.800 β EVENT: Power-Released#3 millis=1636476
01:01:41.800 β EVENT: Power-Released millis=1636476
01:01:42.638 β unit = 0 vol = 0.50, Playing ProffieOS_Voicepack_Skoll/common/mnum/mnum20.wav
01:01:42.673 β channels: 1 rate: 44100 bits: 16
01:01:43.327 β Playing mpercent.wav, channels: 1 rate: 44100 bits: 16
For reference, I just put this fresh battery in because percentage was saying 8% on the one I had in (while volts was reported as 3.52V)
