A simple alpha layer set to add 50% opacity black over a style is messing with my Sparkle, and I have no idea why.
Without that layer, looks great. With it, I get strobe like flashing.
Any idea?
Styles posted here. First works cleanly.
Could it be oscillating?
Low battery → dim → less power draw → voltage goes up → dimming turns off → higher power draw → lower battery voltage → go back to beginning
IF that’s the case, then the solution is to replace IsLessThan with something that has hysteresis; it would only reset back to no dimming once the voltage increases significantly.
I had a similar issue with the power save mode and blade flicker a while back. Ended up giving up on it and just getting extra batteries. When it went into power save, the audio flicker would be way more pronounced, to the point it was jarring.
So would setting it to something pretty large suffice to keep it under the threshold long enough (indefinitely really since the battery is not going to come back up without charging) ?
Something like AlphaL<Black,Scale<HoldPeak<BatteryLevel,Int<999999>,Int<1>>,Int<0>,Int<16384>>>,
Wait - that’s not right.
I gave up on this months ago and just don’t run the blade dim function anymore. I dunno about others but with what I run (V2 PixelSticks) dimming would only give another 10 minutes at best. Even with my play blades running RGB pixels I never saw that much more battery life. Just carry spares.
