Hi,
I’m trying to prepare for connecting all components in my project, where the sword is divided into two zones. The problem is I have to pull most of the wires to the other side and I try to reduce the amount of wires. and here the question arises. Can the diagram I have attached be so implemented? I want to connect one positive cable to the Neopixel tape, LED on the switch, BT, LCD, DC charging. I also want to connect switches, bt, LCD to GND. I know that the generator indicates otherwise, but as I mentioned, i try to reduce the number of wires to a minimum . I also have a problem with the engine. I wish I could control the rotation. How to connect it, to which specific input on the board?
I have attached the generator in mind as what will be submitted. My diagram is ultimately done for the assembly
. I also include an interior design for illustration
Uploading: Schemat.jpg…
