This brings a new compiler which seems to have fewer bugs than the old one, and may also generate slightly more efficient code. There is also a new menu for SPI speed which can largely be ignored.
Please note that Arduno 2.x is required to install this. It can still be used with Arduino 1.x, but only after you install it with Arduno 2.x (or manually).
I just flashed 1 new font/blade style with the 4.1 and more than half of my font/blade styles looks really weird , some wrong colors and other errors i could only show it in a video …
Do they start working again if you go back to 3.6?
If you want to post a video, you’ll need to upload it somewhere else, like youtube, google photos or facebook and the link it here.
I re flashed it with 3.6 and now its back to normal .
I believe that the blade styles that did have spark tip and power-flash where the ones working with errors
So I’ve done some experimenting, and there is definitely a difference i how
TrWipeSparkTipX behaves between 3.6 and 4.1. I’m not sure why yet, but hopefully I can figure it out tomorrow, because it’s bedtime.
It’s unfortunate, because the compiler also fixed some problems.
I’m going to set up a new gcc (13.3) for the beta version of the arduino-proffieboard plugin, let’s hope it has fewer problems…
