Arduino ide on raspberry pi errors
so I’m trying again and I downloaded the arduino ide from the default repositories which v1.8
I have the plugin and I got this error.
Arduino: 1.8.19 (Linux), Board: “Proffieboard V2, Serial, SDCARD (SPI), 80 MHz, full, Fastest”
Board ProffieboardV2-L433CC (platform stm32l4, package proffieboard) is unknown
then turned on the verbose as above.
arduino-builder -dump-prefs -logger=machine -hardware /usr/share/arduino/hardware -hardware /home/maxb/.arduino15/packages -tools /usr/share/arduino/hardware/tools/avr -tools /home/maxb/.arduino15/packages -libraries /home/maxb/Arduino/hardware/libraries -fqbn=proffieboard:stm32l4:ProffieboardV2-L433CC:usb=cdc,dosfs=sdspi,speed=80,pclk=1,opt=o3 -ide-version=10819 -build-path /tmp/arduino_build_139663 -warnings=default -build-cache /tmp/arduino_cache_686137 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=/home/maxb/.arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/14-2-rel1-xpack -prefs=runtime.tools.arm-none-eabi-gcc-14-2-rel1-xpack.path=/home/maxb/.arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/14-2-rel1-xpack -verbose /home/maxb/ProffieOS/ProffieOS.ino
Did you install the arduino-proffieboard plugin?
Yes I did.
I am no expert but these seem to point at errors in the plugin install folder. Maybe there was a problem during the install phase and a re-install might solve it ?
Are you compiling from the Makefile, or from Arduino IDE?
Did you do the steps to get i386 emulation? (I don’t actually think that’s the problem, but it will be required eventually to make it work.)
