Arduino error
hello when i verify with arduino i get the following error
Arduino: 1.8.16 (Windows 10), Board: “Proffieboard V2, Serial + Mass Storage + WebUSB, SDCARD (SPI), 80 MHz, Smallest Code”
In file included from D:\saber\ProffieOS\ProffieOS.ino:579:
D:\saber\ProffieOS\config\mysaber.h:59:67: error: template argument 14 is invalid
59 | InOutTrL<TrWipeSparkTip<White,300>,TrWipeInSparkTip<White,1100>>,
D:\saber\ProffieOS\config\mysaber.h:63:8: error: no matching function for call to ‘StylePtr< >()’
63 | >>()},
In file included from D:\saber\ProffieOS\styles\fire.h:4,
             from D:\saber\ProffieOS\ProffieOS.ino:376:
D:\saber\ProffieOS\styles\style_ptr.h:63:16: note: candidate: ‘template StyleFactory* StylePtr()’
63 | StyleAllocator StylePtr() {
D:\saber\ProffieOS\styles\style_ptr.h:63:16: note: template argument deduction/substitution failed:
D:\saber\ProffieOS\config\mysaber.h:63:8: error: template argument 1 is invalid
63 | >>()},
here is the config mysaber.h - Pastebin.com
You have a comma after your last layer (on line 59).
what about line 63?
I assumed that that is a related error. A lot of the time when you have a syntax error, you get lots of error messages. So you fix the first one, try to compile and see if the rest are still there or not…
i now get all of these errors i dont get it.
D:\saber\ProffieOS\config\mysaber.h:35:9: error: expected primary-expression before ‘)’ token
35 | >>>()},
D:\saber\ProffieOS\config\mysaber.h:38:1309: error: template argument 7 is invalid
38 | AudioFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<200,0,0>>>,TransitionEffectL<TrConcat<TrFade<200>,AlphaL<RotateColorsX<Variation,Rgb16<65535,11439,0>>,SwingSpeed<500>>,TrDelay<30000>,AlphaL<RotateColorsX<Variation,Rgb16<65535,11439,0>>,SwingSpeed<500>>,TrFade<800>>,EFFECT_FORCE>,AlphaL<BrownNoiseFlicker<RotateColorsX<Variation,Red>,Black,300>,SwingSpeed<315>>, LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,225,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<White,Int<0>>,TrWaveX<White,Int<300>,Int<100>,Int<400>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,Mix<Sin<Int<8>>,AlphaL<RotateColorsX<Variation,Rgb16<65535,11439,0>>,Bump<Int<0>,Int<6000>>>,AlphaL<RotateColorsX<Variation,Rgb16<65535,11439,0>>,Bump<Int<0>,Int<22000>>>>,//AlphaL<RotateColorsX<Variation,Rgb16<65535,11439,0>>,Bump<Int<0>,Scale<TwistAngle<>,Int<3000>,Int<20000>>>>,ResponsiveStabL,EffectSequence<EFFECT_BLAST,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,LocalizedClashL<White,80,30,EFFECT_BLAST>,ResponsiveBlastWaveL<White,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,BlastL<White,200,200>,ResponsiveBlastFadeL<White,Scale<SwingSpeed<400>,Int<6000>,Int<12000>>,Scale<SwingSpeed<400>,Int<400>,Int<100>>>,ResponsiveBlastL<White,Scale<SwingSpeed<400>,Int<400>,Int<100>>,Scale<SwingSpeed<400>,Int<200>,Int<100>>,Scale<SwingSpeed<400>,Int<400>,Int<200>>>>,ResponsiveClashL<TransitionEffect<Rgb<255,240,80>,LemonChiffon,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,EffectSequence<EFFECT_POWERSAVE,AlphaL<Black,Int<8192>>,AlphaL<Black,Int<16384>>,AlphaL<Black,Int<24576>>,AlphaL<Black,Int<0>>>,InOutTrL<TrWipe<2650>,TrWipeIn<1375>>,//TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_BOOT>, //TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_NEWFONT>, TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrDelay<2000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<1000>>,EFFECT_BATTERY_LEVEL>>>()},
D:\saber\ProffieOS\config\mysaber.h:37:5: error: parse error in template argument list
37 | StylePtr<Layers<
39 | { “Bank03”, “tracks/LvsV.wav”,
40 | StylePtr<Layers<AudioFlicker<BrownNoiseFlicker<Mix<SwingSpeed<400>,RotateColorsX<Variation,White>,RotateColorsX<Variation,White>>,Stripes<5000,-300,RotateColorsX<Variation,White>,RotateColorsX<Variation,Snow>,RotateColorsX<Variation,White>,RotateColorsX<Variation,White>>,300>,RotateColorsX<Variation,Black>>,TransitionEffectL<TrConcat<TrInstant,White,TrFade<800>>,EFFECT_LOCKUP_END>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<200>>,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,LockupTrL<AlphaL<White,LayerFunctions<Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,ResponsiveBlastWaveL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveBlastWaveL<Rgb<50,50,75>,Int<300>,Int<100>,Int<300>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,EFFECT_CLASH>,TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RotateColorsX<Variation,Rgb<175,175,225>>>,TrFade<1200>>,EFFECT_IGNITION>,ResponsiveStabL,ResponsiveDragL<BrownNoiseFlickerL<White,Int<300>>,TrWipeIn<400>,TrFade<400>>,ResponsiveMeltL<Mix<TwistAngle<>,Red,Orange>,TrWipeIn<600>,TrSmoothFade<600>>,InOutTrL<TrWipeX<Scale<BladeAngle<>,Int<500>,Int<200>>>,TrWipeInSparkTip<White,500>>,AlphaL<Black,Scale<IsLessThan<BatteryLevel,Int<11000>>,Int<0>,Int<7500>>>>>()},
D:\saber\ProffieOS\config\mysaber.h:41:4: error: expected ‘}’ before ‘{’ token
41 | { “Bank04”, “tracks/Ascension.wav”,
D:\saber\ProffieOS\config\mysaber.h:36:4: note: to match this ‘{’
36 | { “Seethe”, “tracks/FinalSteps.wav”,
D:\saber\ProffieOS\config\mysaber.h:30:20: note: to match this ‘{’
30 | Preset presets[] = {
D:\saber\ProffieOS\config\mysaber.h:42:1302: error: expected unqualified-id before ‘,’ token
42 | StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,128,0>>>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>,AlphaL<Black,Scale<IsLessThan<BatteryLevel,Int<11000>>,Int<0>,Int<7500>>>>>()},
D:\saber\ProffieOS\config\mysaber.h:43:4: error: expected unqualified-id before ‘{’ token
43 | { “Bank05”, “tracks/DOF.wav”,
D:\saber\ProffieOS\config\mysaber.h:44:1506: error: expected unqualified-id before ‘,’ token
44 | StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>>,TransitionEffectL<TrConcat<TrFade<400>,Mix<SwingSpeed<400>,AudioFlickerL<Rgb<150,0,0>>,Red>,TrDelay<30000>,Mix<SwingSpeed<400>,AudioFlickerL<Rgb<150,0,0>>,Red>,TrFade<800>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Blue,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>,AlphaL<Black,Scale<IsLessThan<BatteryLevel,Int<11000>>,Int<0>,Int<7500>>>>>()},
D:\saber\ProffieOS\config\mysaber.h:45:4: error: expected unqualified-id before ‘{’ token
45 | { “Magnetic”, “tracks/Traveler.wav”,
Ok, so I downloaded the config file from the pastebin.
I removed the comma at the end of line 59.
I removed one “>” from line 63 (It’s supposed to have two “>”, not three.)
After that it compiled just fine.
i uploaded the config but now when i put in my battery it says, font directory not found, through the speaker how do i fix that?
Make sure the font in your preset exists on your SD card AND is spelled exactly the same.
all of that seems to be correct i checked, when i try the saber it seems that the config didnt update it still wants the old config and sound banks when i try to upload the config i get the following error
Sketch uses 226032 bytes (91%) of program storage space. Maximum is 245760 bytes.
1
2
3
4
5
6
7
8
9
10
also when the upload finishes it automatically disconnects the board
That means the drivers aren’t set up correctly. Try this video.
(Near bottom, search for “df11” in the page if you don’t want to read it all.)
so it uploaded but the blade doesnt light up all the way i assume thats the led count? how do i increase it to the right amount?
i have a 36 inch blade
its fixed it works now thank you very much
I’m unmarking the “solution” here, because while it did solve your problem, it’s not the solution to the problem as written in the top post, which is what the “solution” checkbox is meant for.
