Arduino error (template argument)
Hello there once again,
I am getting the following error when “verifying” my config file. I have included the "top file and blade config below. I am installing a master chassis with a number of accents, crystal chamber, and motor.
Any help clearing the error will be greatly appreciated.
Thank you MTFBWY
Error:
In file included from C:\Users\Marc\Desktop\ProffieOS\ProffieOS\ProffieOS.ino:621:
C:\Users\Marc\Desktop\ProffieOS\ProffieOS\config\scraptec1.h:259:72: error: template argument 2 is invalid
  259 |     WS281XBladePtr<1, blade6Pin, Color8::GRB, PowerPINS<bladePowerPin1,> >()
C:\Users\Marc\Desktop\ProffieOS\ProffieOS\config\scraptec1.h:259:75: error: no matching function for call to 'WS281XBladePtr<1, blade6Pin, Color8::GRB, <expression error> >()'
In file included from C:\Users\Marc\Desktop\ProffieOS\ProffieOS\ProffieOS.ino:583:
C:\Users\Marc\Desktop\ProffieOS\ProffieOS\blades\ws2811_blade.h:391:18: note: candidate: 'template<int LEDS, int DATA_PIN, Color8::Byteorder byteorder, class POWER_PINS, template<int <anonymous>, int <anonymous>, Color8::Byteorder <anonymous>, int <anonymous>, int <anonymous>, int <anonymous>, int <anonymous> > class PinClass, int frequency, int reset_us, int t0h, int t1h, int POWER_OFF_DELAY_MS> BladeBase* WS281XBladePtr()'
  391 | class BladeBase *WS281XBladePtr() {
C:\Users\Marc\Desktop\ProffieOS\ProffieOS\blades\ws2811_blade.h:391:18: note:   template argument deduction/substitution failed:
C:\Users\Marc\Desktop\ProffieOS\ProffieOS\config\scraptec1.h:259:75: error: template argument 4 is invalid
Compilation error: template argument 2 is invalid
Config file
// ProffieOS7 Config File
#define NUM_BLADES 7
#define VOLUME 1000
#define CLASH_THRESHOLD_G 3
#define ENABLE_SSD1306
{ "scraptec;common",  "scraptec/tracks/track.wav",
/* copyright Fett263 JediSurvivor (Primary Blade) OS7 Style
https://www.fett263.com/fett263-proffieOS7-style-library.html#JediSurvivor
OS7.14 v3.01p
Style Option
Base Color: Kyber Select - BaseColorArg - AltColorArg - AltColor2Arg - AltColor3Arg - Rgb<255,0,255> - Rgb<255,68,0> - Rgb<115,15,240> - Rgb<100,100,150> - Rgb<180,130,0> (0)
Kyber Select Interactive Control: While Blade is On, use selected Special Ability to change color (Phase). Requires Alt Font.
*This style REQUIRES Alt Fonts alt000/ to alt008/ to be set up. Uses altchng.wav on change.
Lockup Effect:
[Color: LockupColorArg]
Lightning Block Effect:
[Color: LBColorArg]
Drag Effect:
[Color: DragColorArg]
Melt Effect:
[Color: StabColorArg]
Special Ability 1: Next Phase
Special Ability 2: Previous Phase
Special Ability 3: Select Random Phase
Special Ability 4: Toggle Swing Change (Random / Party Mode) Uses tr00.wav or tr/000/000.wav on toggle (mechanical or menu sound)
StylePtr<Layers<StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<8000>,Int<3000>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<-2600>,Int<-3600>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>,RgbArg<ALT_COLOR_ARG,Rgb<0,255,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<2,72,255>>,RgbArg<ALT_COLOR3_ARG,Rgb<80,50,210>>,Rgb<255,0,255>,Rgb<255,68,0>,Rgb<115,15,240>,Rgb<100,100,150>,Rgb<180,130,0>>,Mix<Int<12000>,Black,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>,RgbArg<ALT_COLOR_ARG,Rgb<0,255,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<2,72,255>>,RgbArg<ALT_COLOR3_ARG,Rgb<80,50,210>>,Rgb<255,0,255>,Rgb<255,68,0>,Rgb<115,15,240>,Rgb<100,100,150>,Rgb<180,130,0>>>,Pulsing<ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>,RgbArg<ALT_COLOR_ARG,Rgb<0,255,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<2,72,255>>,RgbArg<ALT_COLOR3_ARG,Rgb<80,50,210>>,Rgb<255,0,255>,Rgb<255,68,0>,Rgb<115,15,240>,Rgb<100,100,150>,Rgb<180,130,0>>,Mix<Int<8000>,Black,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>,RgbArg<ALT_COLOR_ARG,Rgb<0,255,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<2,72,255>>,RgbArg<ALT_COLOR3_ARG,Rgb<80,50,210>>,Rgb<255,0,255>,Rgb<255,68,0>,Rgb<115,15,240>,Rgb<100,100,150>,Rgb<180,130,0>>>,1400>>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Int<1>>,Int<9>>,Int<-1>>,EFFECT_USER1>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Int<-1>>,Int<9>>,Int<-1>>,EFFECT_USER2>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Scale<RandomF,Int<1>,Int<8>>>,Int<9>>,Int<-1>>,EFFECT_USER3>,TransitionPulseL<TrSelect<IncrementModuloF<EffectPulseF<EFFECT_USER4>,Int<2>>,TrInstant,TrDoEffectX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Scale<RandomF,Int<1>,Int<8>>>,Int<9>>,Int<-1>>>,ThresholdPulseF<SwingSpeed<320>,Int<31000>>>,TransitionEffectL<TrDoEffectX<TrInstant,EFFECT_TRANSITION_SOUND,Int<0>,Int<-1>>,EFFECT_USER4>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<115,15,240>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,0,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,0,0>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,0,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,0,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,0,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,0,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,0,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,0,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,0,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,0,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,0,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<0,0,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<0,0,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<0,0,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<0,0,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,97,0>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,97,0>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>>>(),
/* copyright Fett263 (Accent LED / PCB) OS7 Style
OS7.14 v3.01p
On Behavior: Slow Run Forward [Color: Kyber Select - BaseColorArg - AltColorArg - AltColor2Arg - AltColor3Arg - Rgb<255,0,255> - Rgb<255,68,0> - Rgb<115,15,240> - Rgb<100,100,150> - Rgb<180,130,0>]
Off Behavior: Off [Color: OffColorArg]
Melt Effect:
StylePtr<Layers<TransitionLoop<Black,TrConcat<TrWipe<1000>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>,RgbArg<ALT_COLOR2_ARG,Rgb<0,255,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<80,50,210>>,Rgb<255,0,255>,Rgb<255,68,0>,Rgb<115,15,240>,Rgb<100,100,150>,Rgb<180,130,0>>,TrWipe<1000>>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,97,0>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,97,0>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,31000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrInstant,TrInstant,Black>>>(),
OS7.14 v3.01p
On Behavior: Fast Run Forward [Color: Kyber Select - BaseColorArg - AltColorArg - AltColor2Arg - AltColor3Arg - Rgb<255,0,255> - Rgb<255,68,0> - Rgb<115,15,240> - Rgb<100,100,150> - Rgb<180,130,0>]
Off Behavior: Slow Run Reverse [Color: OffColorArg]
Melt Effect:
StylePtr<Layers<TransitionLoop<Black,TrConcat<TrWipe<200>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>,RgbArg<ALT_COLOR2_ARG,Rgb<0,255,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<80,50,210>>,Rgb<255,0,255>,Rgb<255,68,0>,Rgb<115,15,240>,Rgb<100,100,150>,Rgb<180,130,0>>,TrWipe<200>>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,31000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrInstant,TrInstant,TransitionLoop<Black,TrConcat<TrWipeIn<1000>,RgbArg<OFF_COLOR_ARG,Rgb<255,0,0>>,TrWipeIn<1000>>>>>>(),
OS7.14 v3.01p
On Behavior: Unstable Flicker (Two Color) [Color: Kyber Select - BaseColorArg - AltColorArg - AltColor2Arg - AltColor3Arg - Rgb<255,0,255> - Rgb<255,68,0> - Rgb<115,15,240> - Rgb<100,100,150> - Rgb<180,130,0>]
Off Behavior: Fast Pulse Dim-On [Color: OffColorArg]
Melt Effect:
StylePtr<Layers<RandomPerLEDFlicker<ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>,RgbArg<ALT_COLOR2_ARG,Rgb<0,255,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<80,50,210>>,Rgb<255,0,255>,Rgb<255,68,0>,Rgb<115,15,240>,Rgb<100,100,150>,Rgb<180,130,0>>,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,31000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrInstant,TrInstant,Pulsing<Mix<Int<8192>,Black,RgbArg<OFF_COLOR_ARG,Rgb<55,255,169>>>,RgbArg<OFF_COLOR_ARG,Rgb<55,255,169>>,2000>>>>(),
/* copyright Fett263 JediSurvivor (Accent LED / PCB) OS7 Style
OS7.14 v3.01p
Style Option
Melt Effect:
StylePtr<Layers<StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<8000>,Int<3000>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<-2600>,Int<-3600>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>,RgbArg<ALT_COLOR2_ARG,Rgb<0,255,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<80,50,210>>,Rgb<255,0,255>,Rgb<255,68,0>,Rgb<115,15,240>,Rgb<100,100,150>,Rgb<180,130,0>>,Mix<Int<12000>,Black,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>,RgbArg<ALT_COLOR2_ARG,Rgb<0,255,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<80,50,210>>,Rgb<255,0,255>,Rgb<255,68,0>,Rgb<115,15,240>,Rgb<100,100,150>,Rgb<180,130,0>>>,Pulsing<ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>,RgbArg<ALT_COLOR2_ARG,Rgb<0,255,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<80,50,210>>,Rgb<255,0,255>,Rgb<255,68,0>,Rgb<115,15,240>,Rgb<100,100,150>,Rgb<180,130,0>>,Mix<Int<8000>,Black,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>,RgbArg<ALT_COLOR2_ARG,Rgb<0,255,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<80,50,210>>,Rgb<255,0,255>,Rgb<255,68,0>,Rgb<115,15,240>,Rgb<100,100,150>,Rgb<180,130,0>>>,1400>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,31000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrInstant,TrInstant,Black>>>(),
/* copyright Fett263 (Crystal Chamber) OS7 Style
OS7.14 v3.01p
On Behavior: Solid Color [Color: Kyber Select - BaseColorArg - AltColorArg - AltColor2Arg - AltColor3Arg - Rgb<255,0,255> - Rgb<255,68,0> - Rgb<115,15,240> - Rgb<100,100,150> - Rgb<180,130,0>]
0: crystalDragMulti0Shape - Begin: Wipe In - Style: Intensity Sparking Drag - End: Wipe Out
Melt Effect:
0: crystalMeltMulti0Shape - Begin: Wipe In - Style: Intensity Melt - End: Wipe Out
StylePtr<Layers<ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<255,255,255>>,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>,RgbArg<ALT_COLOR2_ARG,Rgb<0,255,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<80,50,210>>,Rgb<255,0,255>,Rgb<255,68,0>,Rgb<115,15,240>,Rgb<100,100,150>,Rgb<180,130,0>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,31000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrInstant,TrInstant,Black>>>(),
OS7.14 v3.01p
Melt Effect:
"preset0"
    WS281XBladePtr<16, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin4> >(),
    WS281XBladePtr<8, blade3Pin, Color8::GRB, PowerPINS<bladePowerPin5> >(),
    WS281XBladePtr<6, blade4Pin, Color8::GRB, PowerPINS<bladePowerPin6> >(),
    SubBladeWithStride(0, 15, 2, WS281XBladePtr<1, blade5Pin, Color8::GRB, PowerPINS<bladePowerPin6> >()),
    WS281XBladePtr<1, blade6Pin, Color8::GRB,PowerPINS<bladePowerPin1,>()
  , CONFIGARRAY(presets) },
This arrow is pointing the line where the error occurs. On line 259 of your config, it looks like you are missing one closing arrow > at the end of the line right before the parenthesis? But I could be wrong.
And it would be great if you could edit your first post and add 3 back ticks before and after your error and before and after your config. Like this:
your error
your config
It makes it much easier for us to read you config and html can do weird things to the error/config and not displaying properly.
There is a an extra comma here, and also a missing >.
(The < and the > has to match up, like parenthesis.)
Thank you sir,
That worked, it seem to load but got back this:
C:/Users/Marc/AppData/Local/Arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/14-2-rel1-xpack/bin/…/lib/gcc/arm-none-eabi/14.2.1/…/…/…/…/arm-none-eabi/bin/ld.exe:C:\Users\Marc\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\4.6\variants\STM32L452RE-ProffieboardV3/linker_scripts/STM32L452RE_FLASH.ld:224: warning: memory region `SRAM2’ not declared
lto-wrapper.exe: warning: using serial compilation of 6 LTRANS jobs
lto-wrapper.exe: note: see the ‘-flto’ option documentation for more information
Sketch uses 213304 bytes (41%) of program storage space. Maximum is 507904 bytes.
Thoughts?
thank you, updated
Thank you sir, please see the reply below
Looks like it worked.
cool, now time to wire it up to match and test! LOL Thank you
Good evening,
Finally got the saber wired up, board loaded but when powering up getting an audio error.
below is the audio error-
"blade array error"
This is the blade config:
    WS281XBladePtr<1, blade6Pin, Color8::GRB,PowerPINS<bladePowerPin1> >()
Any help would be greatly appreciated.
You have a subblade which is bigger than the string it is a “sub” of.
