ok, running into a similar issue on a very old Tfu1 build that came back for proffie upgrade over an old igniter that was loaded with fonts. i put together a custom sd card, and thought i had a decent config. (this is the part seems to take the longest) Thank you guys again for your eyes and help Arduino: 1.8.19 (Windows 10), Board: "Proffieboard V2, Serial + Mass Storage + W - Pastebin.com
You are missin a }
, without the config, it’s impossible to say more.
Thank you, here is the config #ifdef CONFIG_TOP#include "proffieboard_v2_config.h"#define NUM_BLADES 3#d - Pastebin.com
Line 54: ...,EFFECT_IGNITION>,InOutTrL<TrInstant,TrFade<300>,Black>>>()"yellow"},
is missing a comma before “yellow”:
...,EFFECT_IGNITION>,InOutTrL<TrInstant,TrFade<300>,Black>>>(), "yellow"},
Ok found and changed that one, and still getting many errors Arduino: 1.8.19 (Windows 10), Board: "Proffieboard V2, Serial + Mass Storage + W - Pastebin.com
Anytime you get errors you need to provide the config you uploaded that created those errors, you most likely have additional syntax errors in other presets.
You may want to try the Config Helper Tool, it will handle the syntax for you, just be sure to watch the video and read through all of the selections as you use it.
Thank you for the link. I am still getting used to proffie, and still running 5.9 ( I have built a few configs that worked well. this is my 1st one that I named and built my own font package from my old sd card/board. Will the helper still work on the older version? #ifdef CONFIG_TOP#include "proffieboard_v2_config.h"#define NUM_BLADES 3#d - Pastebin.com
Unfortunately it will not work for 5.9. That’s “ancient” in the world of Proffie, the tool will work for 6 or 7.
You’re missing a comma here:
() "green"},
Should be
(), "green"},
All of your presets should follow this syntax:
StylePtr<>(),
StylePtr<>(),
StylePtr<>(),
"name"
You are also missing a comma before “green” on line 79. You can read the error output and it will tell you on which lines it has a problem. Is the same as before, you should check all your other lines for the same error.
Nicely formatting the lines simplifies this process.
{ "Vader",
"tracks/Vader.wav",
StylePtr<Layers<Stripes<2000,-2500,RotateColorsX<Variation,Red>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<60,0,0>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<30,0,0>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<80,0,0>>,RotateColorsX<Variation,Rgb<30,0,0>>>>,TransitionLoopL<TrConcat<TrWaveX<RandomFlicker<RotateColorsX<Variation,Red>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<80,0,0>>,Black,300>>,Int<400>,Int<100>,Int<200>,Int<0>>,AlphaL<Red,Int<0>>,TrDelayX<Scale<SlowNoise<Int<1500>>,Int<200>,Int<1200>>>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,225,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,AlphaL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<20000>>>,TrFade<400>>,TrConcat<TrInstant,TransitionEffect<NavajoWhite,Rgb<255,225,0>,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>,TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_BOOT>,TransitionEffectL<TrConcat<TrFade<2000>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Red>,10>,Bump<Int<0>,Int<4000>>>,TrFade<2950>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Red>,15>,Bump<Int<0>,Int<5000>>>,TrFade<3000>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Red>,20>,Bump<Int<0>,Int<6000>>>,TrBoing<1000,3>>,EFFECT_PREON>>>(),
StylePtr<Layers<Blue,InOutTrL<TrFade<500>,TrFade<500>,Layers<Black,TransitionEffectL<TrConcat<TrInstant,Mix<Bump<Sin<Int<18>>,Int<20000>>,Black,Blue>,TrDelay<3000>,Mix<Bump<Sin<Int<18>>,Int<20000>>,Black,Blue>,TrFade<500>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrInstant,Mix<Bump<Sin<Int<18>>,Int<20000>>,Black,Blue>,TrDelay<3000>,Mix<Bump<Sin<Int<18>>,Int<20000>>,Black,Blue>,TrFade<500>>,EFFECT_NEWFONT>,TransitionEffectL<TrConcat<TrInstant,Mix<Bump<Sin<Int<18>>,Int<20000>>,Black,Blue>,TrDelay<3000>,Mix<Bump<Sin<Int<18>>,Int<20000>>,Black,Blue>,TrFade<500>>,EFFECT_BOOT>>>,TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<White>,TrFade<1200>>,EFFECT_RETRACTION>>>(),
StylePtr<Layers<StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,Red>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<25,0,0>>,RotateColorsX<Variation,Rgb<60,0,0>>>,300>, RotateColorsX<Variation,Rgb<80,0,0>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>> ,BlastL<White>,TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RotateColorsX<Variation,Rgb<255,150,150>>>,TrFade<1200>>,EFFECT_IGNITION>,InOutTrL<TrInstant,TrFade<300>,Black>>>(),
"Red"},
{ "TieF", "tracks/TieF.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Rgb<180,130,0>>,RotateColorsX<Variation,Rgb<90,65,0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,225,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,AlphaL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<20000>>>,TrFade<400>>,TrConcat<TrInstant,TransitionEffect<NavajoWhite,Rgb<255,225,0>,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>,TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_BOOT>,TransitionEffectL<TrConcat<TrFade<2000>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<180,130,0>>,10>,Bump<Int<0>,Int<4000>>>,TrFade<2950>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<180,130,0>>,15>,Bump<Int<0>,Int<5000>>>,TrFade<3000>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<180,130,0>>,20>,Bump<Int<0>,Int<6000>>>,TrBoing<1000,3>>,EFFECT_PREON>>>(),
StylePtr<Layers<Blue,InOutTrL<TrFade<500>,TrFade<500>,Layers<Black,TransitionEffectL<TrConcat<TrInstant,TransitionLoop<Black,TrConcat<TrWipe<1000>,Blue,TrWipeIn<1000>>>,TrDelay<3000>,TransitionLoop<Black,TrConcat<TrWipe<1000>,Blue,TrWipeIn<1000>>>,TrFade<500>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrInstant,TransitionLoop<Black,TrConcat<TrWipe<1000>,Blue,TrWipeIn<1000>>>,TrDelay<3000>,TransitionLoop<Black,TrConcat<TrWipe<1000>,Blue,TrWipeIn<1000>>>,TrFade<500>>,EFFECT_NEWFONT>,TransitionEffectL<TrConcat<TrInstant,TransitionLoop<Black,TrConcat<TrWipe<1000>,Blue,TrWipeIn<1000>>>,TrDelay<3000>,TransitionLoop<Black,TrConcat<TrWipe<1000>,Blue,TrWipeIn<1000>>>,TrFade<500>>,EFFECT_BOOT>>>,TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<White>,TrFade<1200>>,EFFECT_RETRACTION>>>(),
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Rgb<180,130,0>>,RotateColorsX<Variation,Rgb<90,65,0>>> ,LockupTrL<Stripes<3000,-2000,RandomBlink<30000,Strobe<Rgb<125,125,225>,White,50,1>,Rgb<75,75,150>>,RandomPerLEDFlicker<Rgb<20,20,100>,Rgb<100,100,150>>>,TrWipe<200>,TrWipe<200>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,BlastL<NavajoWhite>,TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RotateColorsX<Variation,Rgb<230,180,80>>>,TrFade<1200>>,EFFECT_IGNITION>,InOutTrL<TrInstant,TrFade<300>,Black>>>(),
"yellow"},
{ "Raxus", "tracks/Raxus.wav",
"Red"},
{ "Felucia", "tracks/Felucia.wav",
StylePtr<Layers<Stripes<3000,-3500,RotateColorsX<Variation,Rgb<180,130,0>>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<45,32,0>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<180,130,0>>,RotateColorsX<Variation,Rgb<22,16,0>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<56,41,0>>,RotateColorsX<Variation,Rgb<22,16,0>>>>,TransitionLoopL<TrConcat<TrWaveX<AudioFlicker<RotateColorsX<Variation,Rgb<180,130,0>>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<56,41,0>>,Black,200>>,Int<400>,Int<100>,Int<200>,Int<0>>,AlphaL<Red,Int<0>>,TrDelayX<Scale<SlowNoise<Int<1000>>,Int<100>,Int<1000>>>>>,TransitionLoopL<TrConcat<TrWaveX<AudioFlicker<RotateColorsX<Variation,Rgb<180,130,0>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<45,32,0>>,300>>,Int<400>,Int<100>,Int<200>,Int<0>>,AlphaL<Red,Int<0>>,TrDelayX<Scale<SlowNoise<Int<1000>>,Int<200>,Int<1500>>>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,225,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,AlphaL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<20000>>>,TrFade<400>>,TrConcat<TrInstant,TransitionEffect<NavajoWhite,Rgb<255,225,0>,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<50>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>,TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_BOOT>,TransitionEffectL<TrConcat<TrFade<2000>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<180,130,0>>,10>,Bump<Int<0>,Int<4000>>>,TrFade<2950>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<180,130,0>>,15>,Bump<Int<0>,Int<5000>>>,TrFade<3000>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<180,130,0>>,20>,Bump<Int<0>,Int<6000>>>,TrBoing<1000,3>>,EFFECT_PREON>>>(),
StylePtr<Layers<StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,Rgb<180,130,0>>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<18,13,0>>,RotateColorsX<Variation,Rgb<43,31,0>>>,300>,RotateColorsX<Variation,Rgb<56,40,0>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>> ,LockupTrL<Stripes<3000,-2000,RandomBlink<30000,Strobe<Rgb<125,125,225>,White,50,1>,Rgb<75,75,150>>,RandomPerLEDFlicker<Rgb<20,20,100>,Rgb<100,100,150>>>,TrWipe<200>,TrWipe<200>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,BlastL<NavajoWhite>,TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RotateColorsX<Variation,Rgb<230,180,80>>>,TrFade<1200>>,EFFECT_IGNITION>,InOutTrL<TrInstant,TrFade<300>,Black>>>(),
"yellow"},
{ "Kashyk", "tracks/Kashyk.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,128>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,225,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,AlphaL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<20000>>>,TrFade<400>>,TrConcat<TrInstant,TransitionEffect<NavajoWhite,Rgb<255,225,0>,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<50>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>,TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_BOOT>,TransitionEffectL<TrConcat<TrFade<2000>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Blue>,10>,Bump<Int<0>,Int<4000>>>,TrFade<2950>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Blue>,15>,Bump<Int<0>,Int<5000>>>,TrFade<3000>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Blue>,20>,Bump<Int<0>,Int<6000>>>,TrBoing<1000,3>>,EFFECT_PREON>>>(),
StylePtr<Layers<Blue,InOutTrL<TrFade<500>,TrFade<500>,Layers<Black,TransitionEffectL<TrConcat<TrInstant,TransitionLoop<Blue,TrConcat<TrBoing<1200,2>,Rgb<0,0,10>,TrFade<1200>>>,TrDelay<3000>,TransitionLoop<Blue,TrConcat<TrBoing<1200,2>,Rgb<0,0,10>,TrFade<1200>>>,TrFade<500>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrInstant,TransitionLoop<Blue,TrConcat<TrBoing<1200,2>,Rgb<0,0,10>,TrFade<1200>>>,TrDelay<3000>,TransitionLoop<Blue,TrConcat<TrBoing<1200,2>,Rgb<0,0,10>,TrFade<1200>>>,TrFade<500>>,EFFECT_NEWFONT>,TransitionEffectL<TrConcat<TrInstant,TransitionLoop<Blue,TrConcat<TrBoing<1200,2>,Rgb<0,0,10>,TrFade<1200>>>,TrDelay<3000>,TransitionLoop<Blue,TrConcat<TrBoing<1200,2>,Rgb<0,0,10>,TrFade<1200>>>,TrFade<500>>,EFFECT_BOOT>>>,TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<White>,TrFade<1200>>,EFFECT_RETRACTION>>>(),
StylePtr<Layers<StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,Red>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<25,0,0>>,RotateColorsX<Variation,Rgb<60,0,0>>>,300>, RotateColorsX<Variation,Rgb<80,0,0>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>> ,LockupTrL<Stripes<3000,-2000,RandomBlink<30000,Strobe<Rgb<125,125,225>,White,50,1>,Rgb<75,75,150>>,RandomPerLEDFlicker<Rgb<20,20,100>,Rgb<100,100,150>>>,TrWipe<200>,TrWipe<200>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,BlastL<NavajoWhite>,TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RotateColorsX<Variation,Rgb<150,150,255>>>,TrFade<1200>>,EFFECT_IGNITION>,InOutTrL<TrInstant,TrFade<300>,Black>>>(),
"blue fire"},
{ "IMPFelucia", "tracks/IMPFelucia.wav",
StylePtr<Layers<StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<180,130,0>>,Black,20>,RotateColorsX<Variation,Rgb<7,5,0>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<190,150,20>>,70>,RotateColorsX<Variation,Rgb<90,65,0>>>,RotateColorsX<Variation,Rgb<56,41,0>>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<1000>>,Stripes<1500,2000,White,Rgb<180,130,0>>,Stripes<1500,-2500,White,Rgb<180,130,0>>>,Int<18000>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,AlphaL<TransitionEffect<White,Rgb<128,0,0>,TrInstant,TrConcat<TrFade<1500>,Red,TrFade<2000>,Orange,TrFade<2500>>,EFFECT_IGNITION>,Bump<Int<0>,Int<6000>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<AudioFlicker<Blue,SteelBlue>,Bump<Int<0>,Int<8000>>>,TrFade<600>>,EFFECT_IGNITION>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>,TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_BOOT>,TransitionEffectL<TrConcat<TrFade<2000>,AlphaL<HumpFlickerL<Red,10>,Bump<Int<0>,Int<4000>>>,TrFade<2950>,AlphaL<HumpFlickerL<Orange,15>,Bump<Int<0>,Int<5000>>>,TrFade<3000>,AlphaL<HumpFlickerL<White,20>,Bump<Int<0>,Int<6000>>>,TrBoing<1000,3>>,EFFECT_PREON>>>(),
StylePtr<Layers<TransitionLoop<Black,TrConcat<TrJoin<TrWipe<800>,TrWipeIn<800>>,RotateColorsX<Variation,DeepSkyBlue>,TrJoinR<TrWipe<500>,TrWipeIn<500>>>>,InOutTrL<TrFade<500>,TrInstant,Layers<Black,TransitionEffectL<TrConcat<TrInstant,TransitionLoop<Black,TrConcat<TrJoinR<TrWipe<500>,TrWipeIn<500>>,RotateColorsX<Variation,DeepSkyBlue>,TrJoin<TrWipe<500>,TrWipeIn<500>>>>,TrDelay<30000>,TransitionLoop<Black,TrConcat<TrJoinR<TrWipe<500>,TrWipeIn<500>>,RotateColorsX<Variation,DeepSkyBlue>,TrJoin<TrWipe<500>,TrWipeIn<500>>>>,TrFade<500>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrInstant,TransitionLoop<Black,TrConcat<TrJoinR<TrWipe<500>,TrWipeIn<500>>,RotateColorsX<Variation,DeepSkyBlue>,TrJoin<TrWipe<500>,TrWipeIn<500>>>>,TrDelay<30000>,TransitionLoop<Black,TrConcat<TrJoinR<TrWipe<500>,TrWipeIn<500>>,RotateColorsX<Variation,DeepSkyBlue>,TrJoin<TrWipe<500>,TrWipeIn<500>>>>,TrFade<500>>,EFFECT_NEWFONT>,TransitionEffectL<TrConcat<TrInstant,TransitionLoop<Black,TrConcat<TrJoinR<TrWipe<500>,TrWipeIn<500>>,RotateColorsX<Variation,DeepSkyBlue>,TrJoin<TrWipe<500>,TrWipeIn<500>>>>,TrDelay<30000>,TransitionLoop<Black,TrConcat<TrJoinR<TrWipe<500>,TrWipeIn<500>>,RotateColorsX<Variation,DeepSkyBlue>,TrJoin<TrWipe<500>,TrWipeIn<500>>>>,TrFade<500>>,EFFECT_BOOT>>>>>(),
"blue"},
{ "Deathstar", "tracks/Deathstar.wav",
StylePtr<Layers<Stripes<3000,-3500,RotateColorsX<Variation,Green>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<0,60,0>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,30,0>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<0,80,0>>,RotateColorsX<Variation,Rgb<0,30,0>>>>,TransitionLoopL<TrConcat<TrWaveX<AudioFlicker<RotateColorsX<Variation,Green>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<0,80,0>>,Black,200>>,Int<400>,Int<100>,Int<200>,Int<0>>,AlphaL<Red,Int<0>>,TrDelayX<Scale<SlowNoise<Int<1000>>,Int<100>,Int<1000>>>>>,TransitionLoopL<TrConcat<TrWaveX<AudioFlicker<RotateColorsX<Variation,Green>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<0,60,0>>,300>>,Int<400>,Int<100>,Int<200>,Int<0>>,AlphaL<Red,Int<0>>,TrDelayX<Scale<SlowNoise<Int<1000>>,Int<200>,Int<1500>>>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,225,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,AlphaL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<20000>>>,TrFade<400>>,TrConcat<TrInstant,TransitionEffect<NavajoWhite,Rgb<255,225,0>,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<50>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<Rgb<255,225,0>,NavajoWhite,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>,TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_BOOT>,TransitionEffectL<TrConcat<TrFade<2000>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Green>,10>,Bump<Int<0>,Int<4000>>>,TrFade<2950>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Green>,15>,Bump<Int<0>,Int<5000>>>,TrFade<3000>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Green>,20>,Bump<Int<0>,Int<6000>>>,TrBoing<1000,3>>,EFFECT_PREON>>>(),
StylePtr<Layers<Blue,InOutTrL<TrFade<500>,TrFade<500>,Layers<Black,TransitionEffectL<TrConcat<TrInstant,TransitionLoop<Black,TrConcat<TrJoin<TrWipe<500>,TrWipeIn<500>>,Blue,TrJoin<TrWipe<500>,TrWipeIn<500>>>>,TrDelay<3000>,TransitionLoop<Black,TrConcat<TrJoin<TrWipe<500>,TrWipeIn<500>>,Blue,TrJoin<TrWipe<500>,TrWipeIn<500>>>>,TrFade<500>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrInstant,TransitionLoop<Black,TrConcat<TrJoin<TrWipe<500>,TrWipeIn<500>>,Blue,TrJoin<TrWipe<500>,TrWipeIn<500>>>>,TrDelay<3000>,TransitionLoop<Black,TrConcat<TrJoin<TrWipe<500>,TrWipeIn<500>>,Blue,TrJoin<TrWipe<500>,TrWipeIn<500>>>>,TrFade<500>>,EFFECT_NEWFONT>,TransitionEffectL<TrConcat<TrInstant,TransitionLoop<Black,TrConcat<TrJoin<TrWipe<500>,TrWipeIn<500>>,Blue,TrJoin<TrWipe<500>,TrWipeIn<500>>>>,TrDelay<3000>,TransitionLoop<Black,TrConcat<TrJoin<TrWipe<500>,TrWipeIn<500>>,Blue,TrJoin<TrWipe<500>,TrWipeIn<500>>>>,TrFade<500>>,EFFECT_BOOT>>>,TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<White>,TrFade<1200>>,EFFECT_RETRACTION>>>(),
StylePtr<Layers<StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,Green>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<0,25,0>>,RotateColorsX<Variation,Rgb<0,60,0>>>,300>,RotateColorsX<Variation,Rgb<0,80,0>>,,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>> ,LockupTrL<Stripes<3000,-2000,RandomBlink<30000,Strobe<Rgb<125,125,225>,White,50,1>,Rgb<75,75,150>>,RandomPerLEDFlicker<Rgb<20,20,100>,Rgb<100,100,150>>>,TrWipe<200>,TrWipe<200>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,BlastL<NavajoWhite>,TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RotateColorsX<Variation,Rgb<150,255,150>>>,TrFade<1200>>,EFFECT_IGNITION>,InOutTrL<TrInstant,TrFade<300>,Black>>>(),
"green"},
{ 0,
WS281XBladePtr<10, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin4, bladePowerPin5> >(),
WS281XBladePtr<1, blade4Pin, Color8::GRB, PowerPINS<bladePowerPin6> >(),
CONFIGARRAY(presets) },
Thank you again guys for your help, got it straigtened out and compiling
