Ahsoka Build
I made these about a year ago (when I had time before getting married). My pride and joy is the box. I had it custom made by a guy on Etsy out of cherry… I hand-engraved the lettering, which took literally forever, scalloped the edges, and stained it. I wrote a small “poem” for the inscription, and it reads:
“Time does not tary to pity our sorrow, but leaves it behind.”
First, the hilt assembly. I spent about 50 hours hand-sanding and then polishing:
Both are installed with CFX, haptic feedback, and Neopixel blades:
I started making the box by drawing the lettering and then gluing to the box surface, tracing with a knife, and then peeling the template off:
Final engraving was done with lots of patience and a Foredom rotary engraver:
It looked kind of plain at this point, so I decided to scallop the top and bottom edges before staining. And here is the final product:
The inside is foam overlaid with black leather:
That box came out super nice. That stain is really well done and the engraving is fantastic.
Thank you! It is Minwax Ebony.
what’s the text translate to ?
It translates to: “Time does not tary to pity our sorrow, but leaves it behind”
Wow is that engraving by hand? Very clean!
What kind of tooling?
Thank you!!
Yes sir, all done by hand with a Foredom rotary tool. Some small carbide cutting bits make short work of the wood…you just have to be careful not to let it get away from you.
