I am using the stranger voice and when i got to “sound bank selection” its the voice of default saber trio , in the file its called “fontmenu”
The CFX has used ‘sound bank selection’ as the wav file triggered when entering that mode. What is happening when you hear it now? How did you trigger it?
It would make more sense on proffie if it said ‘edit preset’. Or are you in edit mode trying to change the font on a particular preset?
its proffie 3.9
check the video at 1:39 https://youtu.be/LRfzhI6QZMQ?si=VzKBI9qKYMrNt4tS&t=98
my saber does the same when selecting font
Look like a long press on aux while the saber is off. That’s in the voice pack and says ‘select preset’. Try renaming the file you want to use (NoSloppy’s wav file) with whatever the file you currently hear is called.
This will not work with EDIT MODE, however, as it will stomp over it and replace it with common again.
Fett263’s prop doesn’t currently support that, I do look forward to his OS8 update though, I’m eager to see what he can do with the new menu system.
Oooo, maybe he’ll add a “Select Voice Pack” menu to it.
Hmm. Now you’re going to make me create mvoiceid.wavs and each pack will speak “Grand Admiral Thrawn” for example. Grrrrr
Hey just wondering if there’s any plans on getting the Jedi high council members, I got a few Jedi soundfonts and would be great to have some of those, but what I would love to have is a ghostbusters or K.I.T.T commons voice packs.
I’ll do that
Added Huyang V2 Voicepack.
*This was initially done by Ksith. I added V2 prompts, and other sound board ports.
Added K.I.T.T.
I have a couple of suggestions for future packs.
Orgus Din
Kyle Katarn
Jedi Nari
Malak
Revan (already mentioned, just adding my endorsement)
Thanks for the Coffee!
Kyle Katarn and Revan are on the to-do list.
For what it’s worth, if you can find me some clean sections of cut-scene clips that could be a good source of what they sound like, it would help me tremendously.
I have this to scavenge for Katern
I have to be honest, I have not played these games. Sometimes it seems the characters change (like mask / no-mask, or good then evil etc…) and I’m not clear on what the expected voice should be, so any help there would also be appreciated. Like timestamps.
Added John_Wick ![]()
Akiro, Mako’s character from Conan the Barbarian?
Would certainly love a Sam Witwer (as Galen Marek) one!
There is one, it’s the Starkiller pack. He just used that name instead of Galen Marek.
With all of the Captain EO/ Star Wars crossover chatter (from Skeleton Crew, which I’m enjoying)…. I don’t have a project to match it yet, but I saw Captain EO as a kid many times and then as an adult when it had its short return at EPCOT. Anyway, yeah one vote for Captain EO voice pack. Nostalgia blast.
