Additional Voicepacks
I mean, I know you use AI and all, and you’ve explained somewhat, but, it’s gotta be some work.
So, I asked my BF which voice pack he wanted. He said Ashoka from the live action series. I was like “That’s the one they don’t have :(”
Love Majel Barrett. Amazing work as always!
Updated most to V2 Voicepacks to accomodate pending ProffieOS8. See 1st post.
Also added a re-vamped Darth Malgus.
More “sinister”, less “cordial”.
ProffieOS_V2_Voicepack_Malgus2
https://www.dropbox.com/scl/fo/3lps8g32vanurux1y7p7u/AN_QGm5OCmZ_YWwflnt6nEs?rlkey=k850xdmpgvuhqfv4r6iigleqc&st=tooqtvis&dl=0
a_Darth_Malgus2
Added LCARS Star Trek Computer Voice.
ProffieOS_V2_Voicepack_LCARS
https://www.dropbox.com/scl/fo/i25ru1gae1z2tx5650cv5/AJLVczEij6A9lQqw5by9WWw?rlkey=7ml0a7pierngu5cisl4glre1g&st=7iwvpfxi&dl=0
a_LCARS
Added Ghost Host and Madame Leota from the Haunted Mansion.
ProffieOS_V2_Voicepack_Ghost_Host
https://www.dropbox.com/scl/fo/ptj1bczoj25uhsp3naf7m/AEDhm_Fwf8Xgu44c_KKcNOo?rlkey=h8inq0265xnd5u9n6qzro16rx&st=9uzbz1lt&dl=0
ProffieOS_V2_Voicepack_Madame_Leota
https://www.dropbox.com/scl/fo/0l7mgk0tkoocu8bboy6j3/AHZ621CQF25NqygQ6AVrNe4?rlkey=g7l1pixvqnb5plajti16rq35y&st=a3ms25ys&dl=0
Really good results.
a_Ghost_Host
a_Madame_Leota
Q: I notice some files changed names in the “v2” voice packs. Will a V2 voice pack still work with Proffie OS7? Or will those few files need to be renamed if using them with OS7?
@BlackDragonN001 100% Backwards compatible. What are you seeing?
I downloaded twice to be sure it wasn’t me, but there seems to be a battlevl.mp3 file in the LCARS pack as well as the battlevl.wav file. Is that supposed to be there?
Ghost Host and Leota (V2!!) look good.
remnant removed. thanks.
looks like the ones that are present in some of the v1 voice packs aren’t even used? “melt color”, “postoff size”, etc. So probably is nothing, I was just winmerging the two to see the diffs.
Correct. Unused prompts were purged.
my suggestions for the voice pack is the ghostbusters crew
A blaster prop that has ray propagation length settings that says ‘Raaaaay…’ :joy:
Hey @NoSloppy I was wondering do you need to change the config “”, to use the font\common\ in the configuration?
How do you mean?
It’s just a common font folder that you would designate in the font search path of the preset like
{ "FontName;common".............
where the common folder is on the root level of the SD card.
I meant if I added voice pack to the font folder. so I would have to add
“FontName;Fotname\common”
Correct, if you want it inside a font itself, (like to use Luke in a Luke font) you would prepend the font directory name as you did there.
The path is relevant, so wherever it is, you say it’s there. (although they should be forward slash dividers)
Hi , could you make it so all the voice in sabertrio sabers change all the voice promts ?
cuase i still hear some old sabertrio default sounds…
thanks
I have no idea about what sabertrio does differently.
If they made custom sounds for custom menus or whatever customization they did to ProffieOS, then you would need to customize those on your own.
I might be able to help if you could completely exactly detail what it is you’re talking about.
