Adding or Enabling "FastOn" feature to Skip Preon Effects? (Sabertrio Proffie)
I understand the prop file used for Sabertrio is a Fett263 file and is supposed to contain a define for “FastOn” using gesture controls to skip preons? I have looked through my config file and can’t seem to find it so far. Is it something I have to add myself or am I missing something?
This is Sabertrio’s Preconfiguration v4.2 for Proffie v3.9
Here’s the relevant (I think) section from my config file:
// ProffieOS7 Config File
#define NUM_BLADES 2
#define VOLUME 600
#define CLASH_THRESHOLD_G 4.0
#define AUDIO_CLASH_SUPPRESSION_LEVEL 5
#define KILL_OLD_PLAYERS
#define FILTER_ORDER 8
#define BLADE_DETECT_PIN 6
#define SAVE_PRESET
#define FETT263_ENABLE_SPIN_MODE
#define FETT263_BM_CLASH_DETECT 8
#define FETT263_FORCE_PUSH
#define FETT263_TWIST_ON
//#define KEEP_SAVEFILES_WHEN_PROGRAMMING
#define FETT263_DISABLE_MULTI_BLAST
#define FETT263_DISABLE_MULTI_BLAST_TOGGLE
#include "../props/saber_sabertrio_buttons.h"
//#include "../props/saber_fett263_buttons.h"
It’s a modified Fett263 file.
Generally speaking, Sabertrio questions are best directed to the sabertrio people.
I did ask once before, but it was with an earlier preconfiguration and they directed me to update to 4.2 because it was already enabled in that version, according to them. It doesn’t appear to be enabled though, so that’s why I thought I’d ask here, but I can certainly ask again.
Yeah you’re better off asking S3 since it’s their version of the code.
fair enough!
