Adding blade style to greyscale font
I purchased a greyscale font, Binary Dark and am trying to add it to my new SaberTrio Vektra. I’ve loaded fonts before but never to a saber with more than 1 blade count. How can I go about adding the necessary lines for the 3 other blades in the config?
I would recommend using @Fett263 blade style generator.
He has rebuilt the greyscale font styles and you can set up the other blades as well all in one spot.
If you don’t want to go that way you can copy the other three styles from another preset
I tried going that route but only the free fonts are loaded into Fett. Tomorrow after work I will try copying them from one of the other presets.
You could watch the demo video from greyscale and try to recreate it and that way you still have the ease of use that @Fett263 offers in building all the styles.
And that way you can make sure they all mesh the way you want them to.
Usually, you start by duplicating the line you have as many times as you need.
(Or, you copy lines from other presets.)
All ya really need to do is as @profezzorn suggests and copy working examples from the working config. Here’s an example for the current crop of Sabertrio Power Core hilts to play with. Just paste in the BinaryDark where the Survivor blade’s listed and leave the following three accent blades there. From there you can play with swapping out the accent blade array styles as you like.
{ "Senza;common", "tracks/none.wav",
/* copyright Fett263 JediSurvivor (Primary Blade) OS7 Style
https://www.fett263.com/fett263-proffieOS7-style-library.html#JediSurvivor
OS7.14 v2.241p
Base Style: Cal Kestis Survivor Green
Base Color: BaseColorArg (0)
Ignition Effect: Glitch On [Color: IgnitionColorArg]
Retraction Effect: Glitch Off [Color: RetractionColorArg]
Lockup Effect:
0: mainLockMulti0Shape - Begin: Full Blade Flash - Style: Intensity AudioFlicker - End: Full Blade Absorb
[Color: LockupColorArg]
Lightning Block Effect:
0: mainLBMulti0Shape - Begin: Full Blade Flash - Style: Strobing AudioFlicker - End: Full Blade Absorb
[Color: LBColorArg]
Drag Effect:
0: mainDragMulti0Shape - Begin: Wipe In - Style: AudioFlicker - End: Wipe Out
[Color: DragColorArg]
Melt Effect:
0: mainMeltMulti0Shape - Begin: Wipe In - Style: Intensity Fire Melt - End: Wipe Out
[Color: StabColorArg]
Blast Effect: Blast Wave (Sound Based) [Color: BlastColorArg]
Clash Effect: Responsive Clash with Wave [Color: ClashColorArg]
StylePtr<Layers<StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<4000>,Int<1800>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<2000>,Int<4000>>,Int<-2800>,Int<-4000>>,Mix<Int<16000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,Mix<Sin<Int<20>,Int<22000>,Int<32768>>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,Mix<Int<8000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<WavLen<>,Int<100>,Int<400>>,Int<100>,Scale<WavLen<>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<AudioFlicker<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<8164>,Black,RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Layers<Stripes<2000,4000,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,Mix<Sin<Int<50>>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,Mix<Int<4096>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,TransitionPulseL<TrConcat<TrExtend<4000,TrInstant>,Stripes<2000,3000,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,Mix<Sin<Int<30>>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,Mix<Int<8192>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,TrFade<4000>>,LockupPulseF<SaberBase::LOCKUP_MELT>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrConcat<TrJoin<TrDelayX<Mult<IgnitionTime<300>,Int<16384>>>,TrWipeX<Mult<IgnitionTime<300>,Int<16384>>>>,Mix<SmoothStep<NoisySoundLevel,Int<-1>>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,TrWipeX<Mult<IgnitionTime<300>,Int<16384>>>>,TrConcat<TrJoin<TrDelayX<Mult<RetractionTime<0>,Int<16384>>>,TrWipeInX<Mult<RetractionTime<0>,Int<16384>>>>,Mix<SmoothStep<NoisySoundLevel,Int<-1>>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>>,TrWipeInX<Mult<RetractionTime<0>,Int<16384>>>>,Black>>>(),
/* copyright Fett263 Rotoscope (Crystal Chamber) OS7 Style
OS7.14 v3.25p
Style Option
Off Behavior Options: Default (0): Off, 1: Fast Pulse Off-On [Color: Match ON Color]
Lockup Effect: NoneLightning Block Effect: NoneDrag Effect: NoneMelt Effect: None */
StylePtr<Layers<RandomFlicker<Stripes<24000,-1400,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<11565>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,
InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,ColorSelect<IntArg<OFF_OPTION_ARG,0>,TrInstant,Black,Pulsing<Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,2000>>>>>(),
/* copyright Fett263 Rotoscope (Accent LED / PCB) OS7 Style
OS7.14 v3.25p
Style Option
Off Behavior: Fast Pulse Off-On [Color: Match ON Color]
InOutTrL<TrInstant,TrInstant,Pulsing<Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,2000>>>>(),
/* copyright Fett263 Rotoscope (Quillion / Secondary Blade) OS7 Style
OS7.14 v3.25p
Style Option
InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<IgnitionTime<250>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>>>(),
  "senza"},
I got it working finally. I had a case of the big dumb and did not notice that the font file had multiple style blades so I was copying all of them into the config. Selecting just one style and replacing a premade font main blade with it worked.
Ha! I forgot that those extras are in there sometimes. Well done.
