Hello there fellow saber enthusiasts
I just wanted to add a simplified short tutorial on how to get sa22c gestures on to your proffieboard and how to set it up
because I did not grasp it fully when in tried it
so if you have the same troubles I had here is a really simplified explanation ![]()
Download the file in
Then head to ProffieOs folder
then the Props folder
replace the sa22c folder with the one you downloaded
then go to your config folder
go to your config file
paste in this text and modify it how ever you want that fits your needs
#define NUM_BUTTONS 1
#define VOLUME 1550
#define CLASH_THRESHOLD_G 3.0
#define ENABLE_SERIAL
#define SA22C_STAB_ON
#define SA22C_THRUST_ON
#define SA22C_SWING_ON
#define Sa22C_SWING_ON_SPEED 250
#define SA22C_TWIST_ON
#define SA22C_TWIST_OFF
#define SAVE_STATE
Swing speed number can be modified or just delete that #define and ad the #define ON you like save changes you made to your config
then upload it with adurino ![]()
Easy Peasy Lemmon Squeezy
Have fun with your saber ![]()
and done hehe
