Hey NoSloppy,
I decided to go back to the beginning and start small. My original config file was huge! With the current config file, everything seems to upload fine. Am now using a Proffie 3.9 and the green power light is on, so I know it’s getting power, but know, no sound when I hook-up the power (no kill switch) and my on/off button is not activating the Proffie.
Here’s my config:
#define NUM_BUTTONS 1
#define VOLUME 1000
#define CLASH_THRESHOLD_G 1.0
#define SA22C_STAB_ON
#define SA22C_SWING_ON
#define SA22C_TWIST_ON
#define SA22C_THRUST_ON
#define SA22C_TWIST_OFF
#define SA22C_FORCE_PUSH
//Vader 1: Original Trilogy//
{"VaderMPP", "boot02.wav",
StylePtr<Layers<StyleFire<Strobe<RotateColorsX<Variation,Rgb<95,0,210>>,Strobe<Rgb<100,100,
150>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,Black>,50,1>,100,1>,Rotate
ColorsX<Variation,Rgb<23,0,65>>,0,5,FireConfig<2,1000,5>,FireConfig<2,1000,5>,FireConfig<2,100
0,5>,FireConfig<2,1000,5>>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<Wh
ite,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strob
e<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFad
e<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,In
t<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1
>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrI
nstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<R
ed,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<
100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,1
6000>,Int<4000>,Int<26000>>,Int<6000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>
>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeI
n<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>
{ 0,
CONFIGARRAY(presets) },
Any thoughts?? I’m sure it’s something really stupid and really simple that I’m just not seeing (I hope).
