It fails trying to install gcc it looks like. I’ve got the logs from ProffieConfig, I couldn’t find out where to find similar logs from Arduino IDE, but the same issue does occur there too.
INFO) [Arduino::ensureDefaultCoreInstalled()] Ensuring Core Installation...
(ERR) [Arduino::ensureDefaultCoreInstalled()] Process error: 5:1
Downloading index: library_index.tar.bz2 0 B / 3.73 MiB 0.00%
Downloading index: library_index.tar.bz2 downloaded
Downloading index: package_index.tar.bz2 0 B / 94.38 KiB 0.00%
Downloading index: package_index.tar.bz2 downloaded
Downloading index: package_proffieboard_index.json 0 B / ? 0.00%
Downloading index: package_proffieboard_index.json downloaded
Downloading missing tool builtin:ctags@5.8-arduino11...
builtin:ctags@5.8-arduino11 0 B / 115.52 KiB 0.00%
builtin:ctags@5.8-arduino11 downloaded
Installing builtin:ctags@5.8-arduino11...
Skipping tool configuration....
builtin:ctags@5.8-arduino11 installed
Downloading missing tool builtin:dfu-discovery@0.1.2...
builtin:dfu-discovery@0.1.2 0 B / 1.81 MiB 0.00%
builtin:dfu-discovery@0.1.2 downloaded
Installing builtin:dfu-discovery@0.1.2...
builtin:dfu-discovery@0.1.2 installed
Downloading missing tool builtin:mdns-discovery@1.0.12...
builtin:mdns-discovery@1.0.12 0 B / 3.16 MiB 0.00%
builtin:mdns-discovery@1.0.12 downloaded
Installing builtin:mdns-discovery@1.0.12...
builtin:mdns-discovery@1.0.12 installed
Downloading missing tool builtin:serial-discovery@1.4.3...
builtin:serial-discovery@1.4.3 0 B / 2.07 MiB 0.00%
builtin:serial-discovery@1.4.3 downloaded
Installing builtin:serial-discovery@1.4.3...
builtin:serial-discovery@1.4.3 installed
Downloading missing tool builtin:serial-monitor@0.15.0...
builtin:serial-monitor@0.15.0 0 B / 2.27 MiB 0.00%
builtin:serial-monitor@0.15.0 downloaded
Installing builtin:serial-monitor@0.15.0...
builtin:serial-monitor@0.15.0 installed
Downloading packages...
proffieboard:arm-none-eabi-gcc@9-2020-q2-update 0 B / 533 B 0.00%
proffieboard:arm-none-eabi-gcc@9-2020-q2-update Server responded with: 403 Forbidden
Error during install: Server responded with: 403 Forbidden
I’m not sure if this is intentional and that 3.6 isn’t meant to be used anymore, but I was holding off on 4.6 due to some of the size issues and other weirdness when it was initially introduced. Not sure how much of that has been fixed yet…
I looked through and it looks like each of the download links (in the JSON) are fine though, so I’m not sure why it’s 403’ing. I don’t have the knowledge to trace the program(s) to know where exactly it’s pulling from. I suppose I also don’t really understand what I’m looking at though. It doesn’t seem very complicated, but I don’t know anything about Arduino’s setup.
