Hey all, not getting 3 buttons working correctly at the moment. Using a 2.2 board and the OS7, all three buttons are wired with common to the bat- and each one to a button pin on the board (power pin, aux pin, aux2 pin). The first two buttons, whichever are connected to power and aux work fine, but the third button just does nothing at all? Interestingly this button changes depending on which button I define as the “aux2” button in the config - any ideas why this wouldn’t be working? Using fett263’s latest button prop, and the num of buttons is defined as 3 in the config top.
Thanks !
