3 accent leds
Hello ! Is it possible to solder three different single-color accent LEDs (for example: green, yellow, and red) ? If so, where should the wires go, and how can I assign different blade styles to each one in the config.ini?
My idea is to use one green, one yellow, and one red LED. I’d like the green and red ones to use styles like the Green, Red Arrow, Luke’s saber from Fett263 library .Is this actually doable, or am I dreaming too big here?
Of course it’s totally doable.
Just assign each one to a different LED pad (the board has 1-6)
Look in the manual, page 14, example b, the 3 right-most accents shown.
thank you so much , I understand now !
