ok guys…hi!!! 1st build 1st post on here… been working with v.2 but JUST saw that this new one is v3.9 I have…
kill switch
speaker
crystal chamber with 1 LED
1 circle LED underneath the chamber
2 buttons monetary (think that’s right?)
is there a diagram out there to help me along with this?Im a year into this hobby after a trip to Savi’s ,got hooked and had to try and build 1 of my own…doing good with soldering too…THANK YOU!!!
Definitely take a look at the configuration generator if you haven’t already. It’ll generate visual wiring diagrams for different setups to give you at least a decent idea of how things should go.
For v2.2:
https://fredrik.hubbe.net/lightsaber/v5/
For v3.9:
https://fredrik.hubbe.net/lightsaber/v6/configurator.html
Once you’ve got that put together (I think you should be able to put together pretty much exactly what you’ve described), you can save it into a .h
file.
The instructions and lots of other documentation for things is on the POD:
I would also recommend my ProffieConfig utility, since it automates all the setup and means you don’t have to fiddle with the code manually, it’s all just checkboxes and dropdowns more or less, and then you can upload straight to the board through it.
That should get you started and get an idea of everything. let us know if you have any more questions.
i appreciate you so much!!! all the computer stuff scares me (been a bricklayer for 30 years… no where near a computer)so ill be back for sure but was told smart people were here…thanx for coming in today i needed ya!
What install will you be using? An RGB led or a Neopixel? The leds on the chamber will be straight leds or neopixel?
Code and bricks are very similar, you just need to follow the right pattern. I have been laying (LEGO) bricks too for the last 40ish years (I’m 51, don’t know when I started ) and started with Proffie code in July 2024. Yes, you will find very smart, very helpful people here.
Whishing you lots of fun in your new “laying” venture.
