1Pin to control crystal chamber and accents leds
I have a problem.
How can I program a single line of RGBW LEDs connected to a single pin to make some of them react differently?
Below is my code. PB says I have a blade error
i only change this line:
SubBlade(0,30,WS281XBladePtr<42, blade4Pin, Color8::GRBw, PowerPINS<bladePowerPin4, bladePowerPin5> >()),
SubBlade(30, 42, NULL)
the code:
#define NUM_BLADES 6
#define VOLUME 1000
const unsigned int maxLedsPerStrip = 291.6666666666667;
#define CLASH_THRESHOLD_G 1.0
#define SHARED_POWER_PINS
#define BLADE_DETECT_PIN 17
#define ENABLE_SERIAL
#define ENABLE_SSD1306
    StyleNormalPtr<GREEN, WHITE, 300, 800>(), "cyan"},
StylePtr<InOutSparkTip<EASYBLADE(GREEN, WHITE), 300, 800> >(), "blue"}
Preset no_blade_presets[] = {
  { "TeensySF", "tracks/mars.wav",
   StyleFirePtr<BLUE, WHITE, 0>(),
  "no blade" },
 { 0, SubBlade(0, 108, WS281XBladePtr<218, bladePin, Color8::GRBw, PowerPINS<bladePowerPin2, bladePowerPin3> >()),
    SubBladeReverse(108, 217, NULL),
    SubBladeWithStride(0, 15, 2, WS281XBladePtr<16, blade2Pin, Color8::GRBw, PowerPINS<bladePowerPin2, bladePowerPin3> >()),
    SubBlade(31,42,WS281XBladePtr<42, blade4Pin, Color8::GRBw, PowerPINS<bladePowerPin4, bladePowerPin5> >()),
SubBlade(0, 30, NULL)
  , CONFIGARRAY(presets) },
 { NO_BLADE, SubBlade(0, 108, WS281XBladePtr<218, bladePin, Color8::GRBw, PowerPINS<bladePowerPin2, bladePowerPin3> >()),
  , CONFIGARRAY(no_blade_presets), "nb_save" }
I have a solution for your problem:
Try changing it to:
SubBlade(30, 41, NULL)
It works! THANK YOU.
Now my only problem is that everything lights up like a rainbow…
One possible reason for that is that the pixels are not in fact RGBW.
If you use RGBW for RGB pixels, or use RGB for RGBW pixels, the result is usually rainbow-like.
You were right!!!
Now everything works. Time for fonts!! :slight_smile:
