1 button menu settings cannot exit
I tried researching, but I didn’t find any post about itI just got a 1 button proffie and flashed the board. Everything is working great until i went in the settings menu
According the the instructions
Hold pwr to go back to main menu
Then hold pwr again to exit
But it just keep saying main menu
Please post your config file so we can see how your saber is configured and what prop file you’re using.
If you’re in a submenu and Exit, it will go to previous menu, if you’re in the Main menu and exit it will Exit edit mode.
Have you tried exiting after Main Menu?
More info available here
I did i was in the menu to adjust swing on ignition(sub menu)
Then exited to where adjust volume is(main menu)
And when i try to exit that it just keeps saying main menu
I have to remove the battery to get out of it coz the button wouldn’t do anything else
Let’s see your config so we can try to recreate.
I found the issue, a bug’s been there on 1-button but hadn’t been seen or reported. The EDIT_SETTINGS_MENU define prevents the menu from exiting. I have a fix submitted for both OSv7 and OSv8.
For the OS7 version you can get here:
Use green “Get Code” button and “Download ZIP”
oh thats great glad theres a fix thank you
Upload the new prop and re flash the board, working beautifully now thank you
Great, glad to hear.
