Very to the point, I like it.
As for the code above, I assume the blades can be in any pixel order like I have? And the order they are defined is the order the blade styles need to be in?
SimpleBladePtr<CH1LED, NoLED, NoLED, NoLED, bladePowerPin4, -1, -1, -1>(),
Is this portion written correctly?
That’s a good idea! However, It’s actually restricted to using 2 metal hinges as conductors. That may give away what I am working on
. I looked into modeling and printing some hinges with passageways, but decided to go with the screen accurate hinges.
I toyed with the idea of splitting one of the hinges and making a non conductive filler.
But I think it would be pretty noticeable. Also, a lot of flexing, so It would have to be silicon or something. the stuff with the largest insulation!
I think I am fine with just being able to fade them out or turn them off.
Wait - another question, can you do more with standard led’s, on an led pad, then fade and turn off?
