So like I said above, you need to follow the Set Up Instructions for my Prop on this page:
See “Set Up for Voice Prompts (Required)” and the other Set Up sections
If you don’t do the Required set up the features of the prop do not work.
If you need help setting the config up use the Config Tool and it will do the config parts for you BUT you still need to set the Voice Prompts up in “common” on your SD card.
