# Upload problem (fixed)
**URL:** <https://crucible.hubbe.net/t/upload-problem-fixed/1288>\
**Category:** ProffieOS\
**Tags:** helpful\
**Created:** [January 22, 2022, 6:52pm UTC](https://crucible.hubbe.net/t/upload-problem-fixed/1288 "2022-01-22T18:52:48Z")\
**Posts on this page:** 1\
**Showing post:** 42
<div class="post-metadata">
**Author:** ![kaQnub](https://crucible.hubbe.net/user_avatar/crucible.hubbe.net/kaqnub/32/693_2.png) [@kaQnub](https://crucible.hubbe.net/u/kaQnub)\
**Post date:** [January 23, 2022, 10:05am UTC](https://crucible.hubbe.net/t/upload-problem-fixed/1288/42 "2022-01-23T10:05:32Z")
</div>
Congrats, you solved the issues within config file.
Now as profezzorn said you might need to setup the board using zadig.
There was a similar topic like this:
> [@Arduino error](https://crucible.hubbe.net/t/arduino-error/858/12):
> That means the drivers aren’t set up correctly. Try this video. [[Proffieboard, Zadig and Ports walkthrough] ](https://www.youtube.com/watch?v=XgT8dq4rhPk)
In there is also a video explaining all the steps. I recommend being focused with this, because you don’t want to accidentally change drivers for the wrong device.
Good luck!
_[View the full topic](https://crucible.hubbe.net/t/upload-problem-fixed/1288)._
