Hello! I received my first proffie neopixel earlier last week. Yesterday I installed several new fonts using a few YouTube guides. Everything works perfectly… except for playing tracks. I’m using sac22c’s 1 button prop file, but when I press the button twice while off, nothing happens. I haven’t changed any of the prop files after I downloaded the 6.7 folder either. I converted the music into 16 bit, mono, wav files. I have a folder labeled “tracks” within my sd card alongside my font folders. I’m unsure of what I’m doing wrong in this scenario.
This is a sample of how my config is currently coded, (I’m not including the whole style).
That would explain why it doesn’t work.
Is tracks/King.wav on your SD card? (in the top level, if it’s in the font directory, then you need to use Awaken/tracks/King.wav in the preset.)
track or tracks matters.
If your preset says { "YourFont", "track/King.wav", then it’s going to look for a folder named track, with no s.
So if you put the file in a folder named tracks then you need to make your preset the same, verbatim. { "YourFont", "tracks/King.wav",
That… was what the preset should have been called… It’s fixed now, but essentially the song(s) were named “King.wav”. I just deleted the “wav” part of the title and the tracks are able to work now. Thx for helping problem solve this.
