I like it!
@LyleStyle I noticed that also. If you hit the button to choose a color and even slightly move or rotate you can catch a different color. Best to hold the saber with two hands to prevent it.
Did something change re: Kyber Select? Can’t seem to get it running on another saber. It seems “Hidden Selection” is now “Random Selection” in the dropdown menus. So I set the main blade base color to that and the CC off behavior to “heartbeat” with Kyber Select as the color.
But the style viewer isn’t showing the CC off behavior when I adjust twist angle even after a preset change click. Also not working the saber itself.
Depends when you generated, making Kyber Select work on all styles required changes to the current approach is different then the first iteration. I’d have to see the style code.
Thanks. Oy, pastebin is firewalled here. I’m gonna split it.
Main:
/* copyright Fett263 ThunderStorm (Primary Blade) OS6 Style
https://fett263.com/fett263-proffieOS6-style-library.html#ThunderStorm
OS6.7 v4.01
Base Style: Thunder and Lightning
Base Color: Kyber Select - Rgb<255,0,0> - Rgb<0,0,255> - Rgb<180,130,0> - Rgb<0,255,0> - 0 - 0 (0)
Kyber Select Interactive Control: Before Igniting the saber will choose a color based on your connection to the Force (Random Selection, changing Preset will reset).
Ignition Effect: Lightning Strike
Retraction Effect: Glitch Off
Melt Effect: Intensity Melt
Clash Effect: Real Clash V1
StylePtr<Layers<Layers<TransitionLoop<ColorSelect<IncrementWithReset<ThresholdPulseF<IncrementWithReset<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_NEWFONT>,Int<1>,Int<1>>,Int<1>>,EffectPulseF<EFFECT_NEWFONT>,Scale<Sin<Int<30>>,Int<0>,Int<5>>,Scale<Sin<Int<30>>,Int<0>,Int<4>>>,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Rgb<0,0,255>,Rgb<180,130,0>,Rgb<0,255,0>>,TrConcat<TrBoing<500,3>,Layers<Stripes<10000,100,Mix<Int<16384>,Black,ColorSelect<IncrementWithReset<ThresholdPulseF<IncrementWithReset<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_NEWFONT>,Int<1>,Int<1>>,Int<1>>,EffectPulseF<EFFECT_NEWFONT>,Scale<Sin<Int<30>>,Int<0>,Int<5>>,Scale<Sin<Int<30>>,Int<0>,Int<4>>>,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Rgb<0,0,255>,Rgb<180,130,0>,Rgb<0,255,0>>>,Mix<Int<3855>,Black,ColorSelect<IncrementWithReset<ThresholdPulseF<IncrementWithReset<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_NEWFONT>,Int<1>,Int<1>>,Int<1>>,EffectPulseF<EFFECT_NEWFONT>,Scale<Sin<Int<30>>,Int<0>,Int<5>>,Scale<Sin<Int<30>>,Int<0>,Int<4>>>,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Rgb<0,0,255>,Rgb<180,130,0>,Rgb<0,255,0>>>,Mix<Int<25700>,Black,ColorSelect<IncrementWithReset<ThresholdPulseF<IncrementWithReset<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_NEWFONT>,Int<1>,Int<1>>,Int<1>>,EffectPulseF<EFFECT_NEWFONT>,Scale<Sin<Int<30>>,Int<0>,Int<5>>,Scale<Sin<Int<30>>,Int<0>,Int<4>>>,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Rgb<0,0,255>,Rgb<180,130,0>,Rgb<0,255,0>>>>,AlphaL<Stripes<8000,-200,ColorSelect<IncrementWithReset<ThresholdPulseF<IncrementWithReset<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_NEWFONT>,Int<1>,Int<1>>,Int<1>>,EffectPulseF<EFFECT_NEWFONT>,Scale<Sin<Int<30>>,Int<0>,Int<5>>,Scale<Sin<Int<30>>,Int<0>,Int<4>>>,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Rgb<0,0,255>,Rgb<180,130,0>,Rgb<0,255,0>>,Mix<Int<7710>,Black,ColorSelect<IncrementWithReset<ThresholdPulseF<IncrementWithReset<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_NEWFONT>,Int<1>,Int<1>>,Int<1>>,EffectPulseF<EFFECT_NEWFONT>,Scale<Sin<Int<30>>,Int<0>,Int<5>>,Scale<Sin<Int<30>>,Int<0>,Int<4>>>,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Rgb<0,0,255>,Rgb<180,130,0>,Rgb<0,255,0>>>>,Int<16384>>>,TrDelayX<Scale<SlowNoise<Int<3000>>,Int<100>,Int<2000>>>>>,TransitionLoopL<TrConcat<TrWipe<200>,RandomBlinkL<Int<30000>,White>,TrJoin<TrDelayX<Scale<SlowNoise<Int<3000>>,Int<300>,Int<3000>>>,TrWipe<200>>>>>,MultiTransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrConcat<TrWipeInX<Mult<IgnitionTime<300>,Int<6553>>>,RandomBlink<30000,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Black>,TrJoin<TrDelayX<Mult<IgnitionTime<300>,Int<19660>>>,TrWipeInX<Mult<IgnitionTime<230>,Int<6553>>>>,Mix<SmoothStep<Scale<SlowNoise<Int<30000>>,IntArg<EMITTER_SIZE_ARG,1000>,Sum<Int<5000>,IntArg<EMITTER_SIZE_ARG,1000>>>,Int<-3000>>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,TrWipeX<Mult<IgnitionTime<300>,Int<19660>>>>,TrConcat<TrJoin<TrDelayX<Mult<RetractionTime<0>,Int<16384>>>,TrWipeInX<Mult<RetractionTime<0>,Int<16384>>>>,Mix<SmoothStep<NoisySoundLevel,Int<-1>>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>>,TrWipeInX<Mult<RetractionTime<0>,Int<16384>>>>,Black>>>(),
CChamber:
/* copyright Fett263 ThunderStorm (Crystal Chamber) OS6 Style
OS6.7 v4.01
Off Behavior: Heart Beat
Ignition Effect: Instant
Retraction Effect: Instant
StylePtr<Layers<Layers<TransitionLoop<ColorSelect<IncrementWithReset<ThresholdPulseF<IncrementWithReset<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_NEWFONT>,Int<1>,Int<1>>,Int<1>>,EffectPulseF<EFFECT_NEWFONT>,Scale<Sin<Int<30>>,Int<0>,Int<5>>,Scale<Sin<Int<30>>,Int<0>,Int<4>>>,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Rgb<0,0,255>,Rgb<180,130,0>,Rgb<0,255,0>>,TrConcat<TrBoing<500,3>,Layers<Stripes<10000,100,Mix<Int<16384>,Black,ColorSelect<IncrementWithReset<ThresholdPulseF<IncrementWithReset<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_NEWFONT>,Int<1>,Int<1>>,Int<1>>,EffectPulseF<EFFECT_NEWFONT>,Scale<Sin<Int<30>>,Int<0>,Int<5>>,Scale<Sin<Int<30>>,Int<0>,Int<4>>>,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Rgb<0,0,255>,Rgb<180,130,0>,Rgb<0,255,0>>>,Mix<Int<3855>,Black,ColorSelect<IncrementWithReset<ThresholdPulseF<IncrementWithReset<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_NEWFONT>,Int<1>,Int<1>>,Int<1>>,EffectPulseF<EFFECT_NEWFONT>,Scale<Sin<Int<30>>,Int<0>,Int<5>>,Scale<Sin<Int<30>>,Int<0>,Int<4>>>,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Rgb<0,0,255>,Rgb<180,130,0>,Rgb<0,255,0>>>,Mix<Int<25700>,Black,ColorSelect<IncrementWithReset<ThresholdPulseF<IncrementWithReset<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_NEWFONT>,Int<1>,Int<1>>,Int<1>>,EffectPulseF<EFFECT_NEWFONT>,Scale<Sin<Int<30>>,Int<0>,Int<5>>,Scale<Sin<Int<30>>,Int<0>,Int<4>>>,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Rgb<0,0,255>,Rgb<180,130,0>,Rgb<0,255,0>>>>,AlphaL<Stripes<8000,-200,ColorSelect<IncrementWithReset<ThresholdPulseF<IncrementWithReset<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_NEWFONT>,Int<1>,Int<1>>,Int<1>>,EffectPulseF<EFFECT_NEWFONT>,Scale<Sin<Int<30>>,Int<0>,Int<5>>,Scale<Sin<Int<30>>,Int<0>,Int<4>>>,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Rgb<0,0,255>,Rgb<180,130,0>,Rgb<0,255,0>>,Mix<Int<7710>,Black,ColorSelect<IncrementWithReset<ThresholdPulseF<IncrementWithReset<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_NEWFONT>,Int<1>,Int<1>>,Int<1>>,EffectPulseF<EFFECT_NEWFONT>,Scale<Sin<Int<30>>,Int<0>,Int<5>>,Scale<Sin<Int<30>>,Int<0>,Int<4>>>,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Rgb<0,0,255>,Rgb<180,130,0>,Rgb<0,255,0>>>>,Int<16384>>>,TrDelayX<Scale<SlowNoise<Int<3000>>,Int<100>,Int<2000>>>>>,TransitionLoopL<TrConcat<TrWipe<200>,RandomBlinkL<Int<30000>,White>,TrJoin<TrDelayX<Scale<SlowNoise<Int<3000>>,Int<300>,Int<3000>>>,TrWipe<200>>>>>,InOutTrL<TrInstant,TrInstant,TransitionLoop<ColorSelect<IncrementWithReset<ThresholdPulseF<IncrementWithReset<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_NEWFONT>,Int<1>,Int<1>>,Int<1>>,EffectPulseF<EFFECT_NEWFONT>,Scale<TwistAngle<>,Int<0>,Int<5>>,Scale<TwistAngle<>,Int<0>,Int<4>>>,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Rgb<0,0,255>,Rgb<180,130,0>,Rgb<0,255,0>>,TrConcat<TrBoing<1200,2>,Mix<Int<1285>,Black,ColorSelect<IncrementWithReset<ThresholdPulseF<IncrementWithReset<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_NEWFONT>,Int<1>,Int<1>>,Int<1>>,EffectPulseF<EFFECT_NEWFONT>,Scale<TwistAngle<>,Int<0>,Int<5>>,Scale<TwistAngle<>,Int<0>,Int<4>>>,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Rgb<0,0,255>,Rgb<180,130,0>,Rgb<0,255,0>>>,TrFade<1200>>>>>>(),
I might not get to look until this weekend, nothing jumps out at me so I’ll have to dig through the script the puts the style together.
No prob thanks for looking at it.
I’ve added “Kyber Select (Hidden)” and the Crystal Off Behavior should work as expected now. You’ll need to have one of the “Kyber Select” options for the Base Color to use Off Behavior. Just refresh the page to get the update.
Works great! Thanks. Tested in saber using “Kyber Select (Hidden)” as described.
Good to hear
